[postgis-users] Cannot access offline value raster
irina.coviello
irina.coviello at imaa.cnr.it
Tue Oct 8 03:55:22 PDT 2013
Dear all,
this is my first post and I hope someone can help me.
I cannot access to the information stored in raster mode out-db.
Rasters are of the type : generic binary + envi hdr file.
I've run the following command:
raster2pgsql -R "C:\Users\user\Desktop\1KM*_?? public.tmp | psql -U postgres -d gisdb_2.1
so, I specify the absolute full path of the file.
But for example, when I run the query:
SELECT ST_Value( rast , 1, 937, 646)
tmp from where rid = 1 ;
or
SELECT St_SummaryStats(rast)
from tmp where rid=1;
the error message is as follows:
ERROR : rt_band_load_offline_data : Can not open raster offline: C:\Users\user\Desktop\1KM_2006_01_16_094500_ch31_T_TB
If I run the query:
select st_width (rast) , st_height (rast)
I get the right information, so I think the metadata are stored correctly.
I haven't problem if the same raster file is stored in mode in-db.
The work environment is:
" POSTGIS =" 2.1.0 r11822 " GEOS =" 3.4.2 - CAPI - 1.8.2 r0 " PROJ =" Rel 4.8.0 , March 6, 2012 " = GDAL " GDAL 1.10.0 , released 24/04/2013 " libxml =" 2.7.8 " LIBJSON =" UNKNOWN " RASTER "
and Windows 7 Professional 64 -bit and Postgres 9.2
