[postgis-users] multipoints to raster
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Thu Oct 10 08:16:08 PDT 2013
I use ST_MapAlgebraFct for this sort of things.
Look at the example in:
http://geospatialelucubrations.blogspot.ca/2012/07/a-slow-yet-1000x-faster-alternative-to.html
that shows how to extract values from another raster coverage. You will have to modify the SQL query in the ST_FirstRasterValue4ma function so it extracts the z value of point instead.
Pierre
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of Radan Šuba
> Sent: Thursday, October 10, 2013 4:43 AM
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] multipoints to raster
> Hey,
> The dataset of points is already sorted and processed, the points are in
> regular grid and they are not overlapping. The relation 1 point = 1 pixel can
> be used, where value of pixel should be Z value. The result should look like
> heat map. However, ST_AsRaster function cannot be used for that. The
> function only create the raster with "footprint of geometry" where all pixels
> have same value.  Any other suggestions?
> Regards
> Radan
> > Hi all,
> > I want to create raster from multipoints geometry where value of pixels is
> > Z value of points. I want to do everything in the database. Is there any
> > simple query for that?
> > So far, I have found the quite complicated way: First create a empty
> > raster with ST_MakeEmptyRaster, secondly ST_AddBand and at the end
> > ST_SetValues which is new functions release recently (PostGIS version
> 2.1).
> > I am wondering how have these conversion been done until now?
> > Thank for any answer
> > Radan
