[postgis-users] ST_Collect
Carsten Hogertz
carsten.hogertz at gmail.com
Fri Oct 11 04:16:17 PDT 2013
Thanks Hugues,
you helped alot. I added some text to your SQL like the following:
WITH myselect
AS (SELECT a.poi_id,
a.geom,
St_collect(b.geom) AS b_geom
FROM
ciss_poi a, ciss_poi b
WHERE
St_dwithin(a.geom, b.geom, ( 0.5 / 111.111 ))
AND a.poi_id != b.poi_id
AND a.desc_string = b.desc_string
GROUP BY
a.poi_id, a.geom)
SELECT ROW_NUMBER() over (order by geom) as id,
St_centroid(St_convexhull(St_collect(geom, b_geom))) as geom
FROM
myselect m
With this statement I get the centroid of the grouped point's convex hulls.
Obviously only the geography.
What can I do to label the information of one of the "initial" points that
formed the convex hull to the new centroid?
Best Regards and thank you very much
Carsten
2013/10/11 Hugues François <hugues.francois at irstea.fr>
> I think the problem is a bit more complicated. The self join is the good
> approach but you can't collect the boolean output of st_dwithin. I should
> have tried something like
> with myselect as (
> select a.id, a.geom, st_collect(b.geom) as b_geom from mytable a,
> mytable b
> where st_dwithin(a.geom, b.geom, 500)
> and a.id != b.id
> group by a.id, a.geom
> select a.id, st_collect(geom, b_geom) from myselect
> Hugues.
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Carsten Hogertz
> *Sent:* Friday, October 11, 2013 9:30 AM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] ST_Collect
> Hello,
> I've got a question about using ST_Collect.
> I have one table with hundrets of thousands of points. Within this table I
> want to collect the points that are within a 500 meter radius and calculate
> a convex hull around them.
> Since the ST_DWithin needs (geom, geom, distance) and I only have one
> table with points, do I first have to perform a self join to identify the
> points within 500 meters and then a ST_Collect to group these points? Or
> can I somehow do it without joining the one table with itself?
> And can I use the ST_DWithin inside the ST_Collect? Like
> ST_Collect(ST_DWithing(geom,geom,distance))?
> Thanks for your help!
> Carsten
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131011/8f8e0cba/attachment.html>
