[postgis-users] ST_Collect
Nicolas Ribot nicolas.ribot at gmail.com
Fri Oct 11 05:14:55 PDT 2013
you could store initial information in a array of values of
desc_string or other attribute, using array_agg function (or create a
concatenated string using string_agg function):
SELECT a.poi_id,
    a.geom,
    array_agg(desc_string) as descs,
    St_collect(b.geom) AS b_geom
Nicolas
On 11 October 2013 13:16, Carsten Hogertz <carsten.hogertz at gmail.com> wrote:
> Thanks Hugues,
> you helped alot. I added some text to your SQL like the following:
> WITH myselect
>     AS (SELECT a.poi_id,
>     a.geom,
> FROM
>     ciss_poi a, ciss_poi b
> WHERE
>     St_dwithin(a.geom, b.geom, ( 0.5 / 111.111 ))
>     AND a.poi_id != b.poi_id
>     AND a.desc_string = b.desc_string
> GROUP BY
>     a.poi_id, a.geom)
> SELECT ROW_NUMBER() over (order by geom) as id,
>     St_centroid(St_convexhull(St_collect(geom, b_geom))) as geom
> FROM
>     myselect m
> With this statement I get the centroid of the grouped point's convex hulls.
> Obviously only the geography.
> What can I do to label the information of one of the "initial" points that
> formed the convex hull to the new centroid?
> Best Regards and thank you very much
> Carsten
> 2013/10/11 Hugues François <hugues.francois at irstea.fr>
>> I think the problem is a bit more complicated. The self join is the good
>> approach but you can't collect the boolean output of st_dwithin. I should
>> have tried something like
>> with myselect as (
>>     select a.id, a.geom, st_collect(b.geom) as b_geom from mytable a,
>> mytable b
>>     where st_dwithin(a.geom, b.geom, 500)
>>     and a.id != b.id
>>     group by a.id, a.geom
>> select a.id, st_collect(geom, b_geom) from myselect
>> Hugues.
>> ________________________________
>> From: postgis-users-bounces at lists.osgeo.org
>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Carsten Hogertz
>> Sent: Friday, October 11, 2013 9:30 AM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] ST_Collect
>> Hello,
>> I've got a question about using ST_Collect.
>> I have one table with hundrets of thousands of points. Within this table I
>> want to collect the points that are within a 500 meter radius and calculate
>> a convex hull around them.
>> Since the ST_DWithin needs (geom, geom, distance) and I only have one
>> table with points, do I first have to perform a self join to identify the
>> points within 500 meters and then a ST_Collect to group these points? Or can
>> I somehow do it without joining the one table with itself?
>> And can I use the ST_DWithin inside the ST_Collect? Like
>> ST_Collect(ST_DWithing(geom,geom,distance))?
>> Thanks for your help!
>> Carsten
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
