[postgis-users] [Win][PostgreSQl 9.2/PostGIS 2.0] Import for beginner
Rémi Cura
remi.cura at gmail.com
Fri Oct 18 01:20:05 PDT 2013
I never used osm data so it's a guess !
solution 1 :
install hstore : in postgres, CREATE EXTENSION hstore;
solution 2 : comment lines creating problems (with phstore),
to comment ad a # at the beginning of the line
Cheers,
Rémi-C
2013/10/18 aGlumLieu <gbrancier at gmail.com>
> (Salut Rémi, merci pour ton aide ! Je continue mon mail en anglais pour
> qu'il
> puisse concerner tous le monde )
> Thank your Remi, but it doesn't work.
> First it was because of I missed to mention the .style file folder.
> So, that currently the last windows command I have:
> *osm2pgsql -s -U postgres -d osm -S "/Program
> Files/osm2pgsql/default.style"
> /aGlumLieu/GeoMkt/rhone-alpes/rhone-alpes.osm*
> But I have a new problem:
> *osm2pgsql SVN version af61cae663 (64bit id space)
> release notes: 'Windows version built by Dominik Perpeet
> <http://www.customdebug.com/osm2pgsql/index.html>'
> Using projection SRS 900913 (Spherical Mercator)
> Error reading style file line 151 (fields=4)
> flag 'phstore' is invalid in non-hstore mode
> Error occured, cleaning up*
> In the default.style file, in line 151, there are
> /# Area tags
> # We don't make columns for these tags, but objects with them are areas.
> # Mainly for use with hstore
> way abandoned:aeroway text phstore
> way abandoned:amenity text phstore
> way abandoned:building text phstore
> way abandoned:landuse text phstore
> way abandoned:power text phstore
> way area:highway text phstore/
> I don't know what I have to do...
> http://postgis.17.x6.nabble.com/Win-PostgreSQl-9-2-PostGIS-2-0-Import-osm-data-for-beginner-tp5004469p5004478.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131018/e32942dc/attachment.html>
