[postgis-users] Definition of St_Distance in case of 2 non point geometries
Nicklas Avén
nicklas.aven at jordogskog.no
Fri Oct 18 06:39:01 PDT 2013
If I understand you right your assumption is true.
What makes you wondering?
In 2d you will always get the distance to a vertexpoint in at least one of the two geometries.
You can use ST_ShortestLine to see between what points the distance is calculated.
So:
SELECT ST_Distance('LINESTRING(1 1, 1 10)'::geometry, 'LINESTRING(2 5, 10 5)'::geometry);
returns 1
and
SELECT ST_AsText(ST_ShortestLine('LINESTRING(1 1, 1 10)'::geometry, 'LINESTRING(2 5, 10 5)'::geometry));
returns 'LINESTRING(1 5, 2 5)'::geometry
geography type calculations is of course another story.
HTH
Nicklas
2013-10-18 Peter Hopfgartner wrote:
I took it for granted, that ST_Distance between two two dimensional
>geometries followes the definition of
>dist(A, B) = inf(d(a,b)), where a is an arbitrary point in set A and b
>an arbitrary point in set B and d() is the euclidean distance
>For some reason I'm now wondering if my assumption is true.
>Thanks for your patience,
>Peter
>Peter Hopfgartner
>R3 GIS
>web : http://www.r3-gis.com
>_______________________________________________
>postgis-users mailing list
>postgis-users at lists.osgeo.org
>http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131018/5dcaa98c/attachment.html>
