[postgis-users] Definition of St_Distance in case of 2 non point geometries
Rémi Cura
remi.cura at gmail.com
Fri Oct 18 07:42:18 PDT 2013
Hey,
this is partially true.
It behaves strangely when you hit precision limits.
Cheers,
Rémi-C
2013/10/18 Nicklas Avén <nicklas.aven at jordogskog.no>
> If I understand you right your assumption is true.
> What makes you wondering?
> In 2d you will always get the distance to a vertexpoint in at least one
> of the two geometries.
> You can use ST_ShortestLine to see between what points the distance is
> calculated.
> So:
> SELECT ST_Distance('LINESTRING(1 1, 1 10)'::geometry, 'LINESTRING(2 5,
> 10 5)'::geometry);
> returns 1
> and
> SELECT ST_AsText(ST_ShortestLine('LINESTRING(1 1, 1 10)'::geometry,
> 'LINESTRING(2 5, 10 5)'::geometry));
> returns 'LINESTRING(1 5, 2 5)'::geometry
> geography type calculations is of course another story.
> HTH
> Nicklas
> 2013-10-18 Peter Hopfgartner wrote:
> I took it for granted, that ST_Distance between two two dimensional
> >geometries followes the definition of
> >dist(A, B) = inf(d(a,b)), where a is an arbitrary point in set A and b
> >an arbitrary point in set B and d() is the euclidean distance
> >For some reason I'm now wondering if my assumption is true.
> >Thanks for your patience,
> >Peter
> >Peter Hopfgartner
> >R3 GIS
> >web : http://www.r3-gis.com
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at lists.osgeo.org
> >http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131018/959f6378/attachment.html>
