[postgis-users] Definition of St_Distance in case of 2 non point geometries
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 18 10:43:50 PDT 2013
Except when one or more of the geometries includes circular arcs (v 2.1+)
P
On Fri, Oct 18, 2013 at 6:39 AM, Nicklas Avén
<nicklas.aven at jordogskog.no> wrote:
> If I understand you right your assumption is true.
> What makes you wondering?
> In 2d you will always get the distance to a vertexpoint in at least one of
> the two geometries.
> You can use ST_ShortestLine to see between what points the distance is
> calculated.
> So:
> SELECT ST_Distance('LINESTRING(1 1, 1 10)'::geometry, 'LINESTRING(2 5, 10
> 5)'::geometry);
>  returns 1
> and
> SELECT ST_AsText(ST_ShortestLine('LINESTRING(1 1, 1 10)'::geometry,
> 'LINESTRING(2 5, 10 5)'::geometry));
> returns 'LINESTRING(1 5, 2 5)'::geometry
> geography type calculations is of course another story.
> HTH
> Nicklas
> 2013-10-18 Peter Hopfgartner wrote:
> I took it for granted, that ST_Distance between two two dimensional
>>geometries followes the definition of
>>dist(A, B) = inf(d(a,b)), where a is an arbitrary point in set A and b
>>an arbitrary point in set B and d() is the euclidean distance
>>For some reason I'm now wondering if my assumption is true.
>>Thanks for your patience,
>>Peter
>>Peter Hopfgartner
>>R3 GIS
>>web : http://www.r3-gis.com
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at lists.osgeo.org
>>http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
