[postgis-users] Definition of St_Distance in case of 2 non point geometries
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Sat Oct 19 06:00:40 PDT 2013
Thanks for the reply. I have a bizarre behavior with version 1.5.8/GEOS
3.3.3. I'll try to extract a test case in order to discuss it in more
detail.
Thanks for the replies,
Peter
On 10/18/2013 03:39 PM, Nicklas Avén wrote:
> If I understand you right your assumption is true.
> What makes you wondering?
> In 2d you will always get the distance to a vertexpoint in at least
> one of the two geometries.
> You can use ST_ShortestLine to see between what points the distance is
> calculated.
> So:
> SELECT ST_Distance('LINESTRING(1 1, 1 10)'::geometry, 'LINESTRING(2 5,
> 10 5)'::geometry);
> returns 1
> and
> SELECT ST_AsText(ST_ShortestLine('LINESTRING(1 1, 1 10)'::geometry,
> 'LINESTRING(2 5, 10 5)'::geometry));
> returns 'LINESTRING(1 5, 2 5)'::geometry
> geography type calculations is of course another story.
> HTH
> Nicklas
> 2013-10-18 Peter Hopfgartner wrote:
> I took it for granted, that ST_Distance between two two dimensional
> >geometries followes the definition of
> >dist(A, B) = inf(d(a,b)), where a is an arbitrary point in set A and b
> >an arbitrary point in set B and d() is the euclidean distance
> >For some reason I'm now wondering if my assumption is true.
> >Thanks for your patience,
> >Peter
> >Peter Hopfgartner
> >R3 GIS
> >web : http://www.r3-gis.com
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at lists.osgeo.org
> >http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
web : www.r3-gis.com
mail : peter.hopfgartner at r3-gis.com
phone: +39 0473 494949
fax : +39 0473 069902
ATTENZIONE! Le informazioni contenute nella presente e-mail e nei documenti eventualmente allegati sono confidenziali. La loro diffusione, distribuzione e/o riproduzione da parte di terzi, senza autorizzazione del mittente è vietata e può violare il D. Lgs. 196/2003. In caso di ricezione per errore, Vogliate immediatamente informare il mittente del messaggio e distruggere la e-mail.
ACHTUNG! Die in dieser Nachricht oder in den beigelegten Dokumenten beinhalteten Informationen sind streng vertraulich. Ihre Verbreitung und/oder ihre Wiedergabe durch Dritte ist ohne Erlaubnis des Absenders verboten und verstößt gegen das Legislativdekret 196/2003. Sollten Sie diese Mitteilung irrtümlicherweise erhalten haben, bitten wir Sie uns umgehend zu informieren und anschließend die Mitteilung zu vernichten.
WARNING! This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden and could be against the law (D. Lgs. 196/2003)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131019/e76f7b28/attachment.html>
