[postgis-users] PostGIS Raster Area from a Clip
Marcello Benigno
benigno.marcello at gmail.com
Sat Oct 19 05:53:55 PDT 2013
Hi All
I converted a raster to vector format, where the pixel values range from 1
to 8, then exported to PostGIS and made the following query:
SELECT foo.value, ST_area(foo.geom::geography)
FROM (
SELECT c.value,
ST_Union(ST_Intersection(f.geom, c.geom)) as geom
FROM fazendas f, capacidade_vect c
WHERE ST_Intersects(f.geom, c.geom)
AND f.gid = 2
GROUP BY c.value
ORDER BY c.value
) AS foo;
I wonder if it is possible to obtain the same results using the table in
raster format (in this case *capacidade_rast*, not *_vect*), because as
described above takes too long. I'm complete newbie in PostGIS Raster...
Could anyone help me to build this query?
Thanks in advance,
*Marcello Benigno B. de Barros Filho*
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
http://profmarcello.blogspot.com
http://about.me/marcello.benigno
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131019/11085c67/attachment.html>
