[postgis-users] Ubuntu installation guide - review?
franco base frenk.calza at gmail.com
Fri Oct 25 02:52:03 PDT 2013
Hi, Matthew.
Thanks for your guide.
I follow it on Ubuntu 12.04.
But I dont' understand why
at the end,
after postgis and postgres installation,
when I run
sudo apt get install qgis,
the apt get try to remove libgdal1, postgis postgresql-9.3-postgis-2.1
thanks
2013/10/24 Rémi Cura <remi.cura at gmail.com>
> Thanks for the guide it's very cool.
> Maybe you can add at a visible place that this installation is for 12.04
> (or not, some command change).
> Also there is some install step missing for postgres, like configuring
> postgresql.conf and the other conf file to change loggin permission
> (default option : the data base listen to nothing).
> It is very good work and I wish it was available a few months ago !
> Cheers,
> Rémi
> 2013/10/24 Guido Stein <guido at guidostein.com>
>> Thanks Matthew for writing this up,
>> I have a couple questions
>> * Can more of this be done within the command line instead of opening an
>> editor or web application?
>> * You mention a "sudo apt­get install libgdal1" option, but why is that
>> optional?
>> Thanks again,
>> Guido
>> On Thu, Oct 24, 2013 at 4:55 AM, James David Smith <
>> james.david.smith at gmail.com> wrote:
>>> That's really great Matthew. Well done.
>>> On 23 October 2013 21:12, Matthew Baker <mattbaker at gmail.com> wrote:
>>> > Hi all,
>>> > I've been refining a (fairly) simple installation guide for Ubuntu
>>> which
>>> > pulls from from the Postgresql apt repository. I wonder if anyone
>>> might have
>>> > a look at it and let me know if its ok.
>>> > I have placed the PDF here:
>>> https://drive.google.com/file/d/0Bxh7puyDgHHoV1llRVlkb3NDUk0/edit?usp=sharing
>>> > It will install:
>>> > Postgresql 9.3
>>> > PGAdmin3 v1.18
>>> > PostGIS 2.1
>>> > QGIS 2.0
>>> > Any feedback is appreciated!
>>> > Thank you,
>>> > -m
>>> > Matthew Baker mattbaker at gmail.com 909-647-8058 @mapbaker
>>> > sent from Thunderbird on Ubuntu
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > postgis-users at lists.osgeo.org
>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131025/eef42d22/attachment.html>
