[postgis-users] Ubuntu installation guide - review?
bracket
ksurey at gmail.com
Fri Oct 25 10:04:08 PDT 2013
Thank you for assembling these instructions.
Some suggestions:
1) I agree that a command-line only set of instructions would be helpful.
Also, consider a outline at the top.
2) My predicament is usually that I want to versions of Postgres on my linux
system and that I usually get scrambled up in the housekeeping to keep the
two installs separate and working. For instance, I now have just postgres
9.1 installed because I made such a mess installing 9.1 and 9.2- with parts
from one bleeding into parts of the other.... If the instructions do not
cover a clustered approach- at least warn the novices (me.) to be careful.
3) Add a section for common error messages.
thank you again.
Katie Urey
View this message in context: http://postgis.17.x6.nabble.com/Ubuntu-installation-guide-review-tp5004581p5004595.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
