[postgis-users] spatial index for topology?
Rémi Cura
remi.cura at gmail.com
Mon Oct 28 01:48:25 PDT 2013
Hey,
in QGIS you will have slow visualization essentially on faces.
If your topogeom are based on node or edge it is faster.
If not, I use materialized view (requiere postgres 9.3), as a "buffer" for
qgis. The problem is QGIS 2.0 doesn't support yet materialized view, so you
have to create a proxy view onto your materialized view for qgis!
It is a bit of useless code but it is a great comfort gain.
Also, you can use QGis visualisation settings to make the element appears
dynamically, again this is better than just waiting with blank screen
Cheers,
Rémi-C
2013/10/28 Christophe Vergon <christophevergon-girtec at orange.fr>
> OK.
>> So for now, working with a large topology data set is not practical.
>> Some processing should not be a problem, if it operates on the primitives,
>> which are indexed.
> I'm not sure to understand all of the problem, the way I use to link
> Buissnes Object (here "tronfluv" ) and Primitives in a request is as folow
> SELECT st_AsBinary(st_**GetFaceGeometry('topocommune',**face_id)),idtronfluv
> FROM topocommune.face,topocommune.**relation, schemaname.tronfluv WHERE
> layer_id=:lid AND mbr && st_LineFromText(:rg,srid) AND face_id=element_id
> AND (the_topo).id=topogeo_id;
> Nota : :rg parameter who describe a polyline (a rectangle in fact).
> It works well and relatively fast with a large topology dataset (23 518
> Buissnes Object "tronfluv" in my Database)
> Christophe
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**users<http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131028/84881815/attachment.html>
