[postgis-users] Multiple Geometries in Single View
Wesley Roberts jwesroberts at gmail.com
Tue Oct 29 02:42:55 PDT 2013
Thanks Remi,
I am looking at a SpatialLite solution now. Many thanks for your inputs.
The WMS approach is a little advanced at the moment so we will stick to the
data sharing approach.
Regards,
Wesley
On Tue, Oct 29, 2013 at 10:40 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> We don't know much about your organisation,
> you may went to send all your data for each review, this is similar to
> sending shapefile, and to sending a one file sqlite database.
> On the other hand you can simply give access to your data trough internet
> to your reviewers (and only them). This way they can browse it and use it
> for computation.
> If for review purpose I suspect they don't really need to have it but more
> to use it.
> The same idea more sophisticated (again depending your need) is to put
> your data into a web map service server (
> http://fr.wikipedia.org/wiki/Web_Map_Service).
> To make it simple is the same kind of thing than google map. It allow to
> visually use the data. (for a visual check for instance).
> Cheers.
> Rémi-C
> 2013/10/29 Wesley Roberts <jwesroberts at gmail.com>
>> Dear Rémi-C and Bo Victor,
>> Many thanks for your responses. It seems my idea will not work as I
>> thought. Perhaps I should look for alternative methods to share my data. My
>> main aim is to reduce the clutter of sharing shapefiles and making it
>> easier for the auditor to access and use our data. Perhaps the spatiallite
>> db approach is one to use.
>> I looked around for methods for sharing a postGIS database and it is not
>> as easy as one would think. As I understand it there is no single file or
>> folder containing the database and tables that can be simply copied to a
>> shared folder. Even setting up a database in a non-standard location is
>> difficult enough. I will start a separate question regarding sharing
>> postGIS databases.
>> Spatiallite may be the best alternative.
>> Many thanks and kind regards,
>> Wesley
>> On Mon, Oct 28, 2013 at 5:20 PM, Rémi Cura <remi.cura at gmail.com> wrote:
>>> Hey,
>>> as far as I know you cant load directly different geometry type into
>>> qgis (http://trac.osgeo.org/qgis/ticket/167).
>>> If you have a table with different type in in (point, line, polygon),
>>> qgis will ask you to chose which geometry you want to load.
>>> If you have a table with a column with "geometry collection", qgis won't
>>> load it.
>>> This being said, it is easilly worked around (still a hassle) :
>>> simple : if you have a column with different geometry type, load it
>>> multiple time in qgis selecting each time a different geometry type
>>> simple : if you have a column with geometry collection : use
>>> ST_CollectionExtract to be in the previous case
>>> Note:  if you are tired of selecting the type of geometry in qgis, you
>>> can create view with only one type of geometry.
>>> dirty way : simply convert everything to polygon ! : use ST_Buffer with
>>> small area to convert point and line to polygon.
>>> Don't hesitate if you need more details.
>>> Cheers,
>>> Rémi-C
>>> 2013/10/28 Wesley Roberts <jwesroberts at gmail.com>
>>>> Dear PostGIS users,
>>>> I am a new postgis user and have a question regarding views and
>>>> multiple geometry types. I understand that I can create a *view* where
>>>> I select a portion of my data using an sql statement and view that *view
>>>> *in QGIS. I would like to know if it is possible to create a *view *that
>>>> contains multiple geometry types, so for example: a view displaying points
>>>> lines and polygons from different tables within the my db?
>>>> The context to this question is as follows. Our organization needs to
>>>> share a number of GIS layers with an auditor as part of our validation
>>>> process. Instead of sending the auditor a "bucket load" of shapefiles with
>>>> instructions on what to look at, I would prefer to share one postGIS DB
>>>> with all the layers in tables and all of our geo-spatial requirements in
>>>> views. Is this possible?
>>>> Many thanks and looking forward to your responses.
>>>> Wesley
>>>> Dr Wesley Roberts
>>>> Cell: +27(0)83 5355 646
>>>> skype: roberts-w
>>>> I hear...I forget
>>>> I see...and I remember
>>>> I do...and I understand
>>>> Ancient Chinese Proverb
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Dr Wesley Roberts
>> skype: roberts-w
>> I hear...I forget
Dr Wesley Roberts
skype: roberts-w
I hear...I forget
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131029/2f550026/attachment.html>
