[postgis-users] PostGIS 2.1: missing geometry_gist_sel_2d
Luca Morandini
lmorandini at ieee.org
Tue Sep 3 02:55:51 PDT 2013
On 09/03/2013 07:48 PM, Sandro Santilli wrote:
> Did you follow the proper upgrade procedure ?
> What does postgis_full_version() tell you ?
Nothing encouraging:
POSTGIS="2.1.0 r11822" GEOS="3.4.0dev-CAPI-1.8.0 r3866" PROJ="Rel. 4.7.1, 23
September 2009" LIBXML="2.7.6" (core procs from "2.1.0SVN r9949" need upgrade)
TOPOLOGY (topology procs from "2.1.0SVN r9949" need upgrade)
> The missing function should not be referenced by a 2.1 install,
> so must be some old type still being around since 2.0 times.
Ah, the would explain it.
> You needed to follow the so called "hard upgrade" procedure to
> go from 2.0 to 2.1.
OK, will do.
Thanks a lot,
Luca Morandini
Data Architect - AURIN project
Melbourne eResearch Group
Department of Computing and Information Systems
University of Melbourne
Tel. +61 03 903 58 380
Skype: lmorandini
