[postgis-users] update to 2.0.4
Sandro Santilli
strk at keybit.net
Tue Sep 10 13:41:56 PDT 2013
On Tue, Sep 10, 2013 at 07:28:50PM +0200, Mario Jurcevic wrote:
> Hi,
> what is the correct way to upgrade from 2.0.3 to 2.0.4?
> By running postgis_upgrade_minor_2.0...
> gives error:
> cannot drop function addgeometrycolumn(character varying,character
> varying,character varying,character varying,integer,character
> varying,integer,boolean) because extension postgis requires it
> HINT: You can drop extension postgis instead.
That's because you evidently had PostGIS installed as an extension
> With "alter extension" gives no error but is everything updated?
It should. Check with
SELECT postgis_full_version();
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
