[postgis-users] upgrading from postgresql 8.4 - postgis 1.3.6 to postgresql 9.2/postgis2.0
Athanasios Kostopoulos athanasios.kostopoulos at classmarkets.com
Wed Sep 11 08:44:59 PDT 2013
Thanks for your input. I tried that approach and it did not work. It gave
the same results when I go the "short" way around by create extensions.
Afterwards I tried with Postgres 8.4, going "the long way". The same
results.
Specifically:
[snipped lots of messages like ERROR:  syntax error at or near "'
                UPDATE '"
LINE 1: EXECUTE '
then eventually:
CREATE FUNCTION pygeocode(text) RETURNS character varying
    LANGUAGE plpythonu
    AS $_$"
LINE 1: $_$;
ERROR:  syntax error at or near "#"
LINE 1: # This retrieves the URL from Google,
invalid command \n
out of memory
(out of memory happens after a while)
Any tips or ideas are more than welcome. The perl script has not been
tested with postGIS version 1.3.6 - anyone had any success with that
particular version?
On Fri, Sep 6, 2013 at 5:59 PM, Marcos Cano <mcano at stsa.info> wrote:
> I did that a few months ago... Basically what I did was..
> Install pg9.2.4 (latest stable version) with disable-integer-datetimes
> And postgis 2.0.3 pointing against this Postgres version  with :
>  --with-pgconfig= thepath/to/pg9.2.4/bin/pg_config
> I run the both servers the newest in a different tcp port because there
> were something's I still need from
> That server.
> Do a pg_dump of the postgis enabled database..  I did the pg_dump with the
> /bin/ folder of
> The older version.
> In the new server I created a spatially enabled database make sure you
> make it the long way (without EXTENSIONS)
> Then I did a restore with the perl script
> Greetings
> On Friday, September 6, 2013, Athanasios Kostopoulos wrote:
>> Dear list,
>> I have a problem that proves to be quite the brain-teaser (at least for
>> me).
>> I have an ancient database (8.4.X) integrated with postGIS 1.3.6.
>> Clearly, this while currently working will reach end of life soon and needs
>> to be upgraded.
>> On a Debian wheezy system, I installed postgres 9.2/postgis2.0 - all from
>> the apt repositories provided by postgres. When I try to do things the
>> recommended way from postGIS (processing the backup with the perl script)
>> during restore I get a few errors and constantly increasing memory usage,
>> until the restore process will die with an "out of memory error". When I
>> try to restore the "pure" dump, I get a number of errors.
>> Now, I understand that I am talking a big increase in major versions,
>> including some non backwards compatible changes in postgis but such an
>> upgrade should be feasible. Can someone give me a small push, so I can move
>> forward with this? I would prefer to upgrade to the latest versions of
>> postgresql and postGIS, if such a thing is possible.
>> Thanks in advance for any replies.
>> classmarkets GmbH | Schumannstraße 6 | 10117 Berlin | Deutschland
>> Tel: +49 (0)30 56 59 001-0 | Fax: +49 (0)30 56 59 001-99 |
>> www.classmarkets.com
>> Amtsgericht Charlottenburg HRB 111815 B | USt.Id.Nr: DE 260731582
>> Geschäftsführer: Veit Mürz, Fabian Ströhle
>> Diese Nachricht (inklusive aller Anhänge) ist vertraulich. Sie darf
>> ausschließlich durch den vorgesehenen Empfänger und Adressaten gelesen,
>> kopiert oder genutzt werden. Sollten Sie diese Nachricht versehentlich
>> erhalten haben, bitten wir, den Absender (durch Antwort-E-Mail) hiervon
>> unverzüglich zu informieren und die Nachricht zu löschen. Jede unerlaubte
>> Nutzung oder Weitergabe des Inhalts dieser Nachricht, sei es vollständig
>> oder teilweise, ist unzulässig. Bitte beachten Sie, dass E-Mail-Nachrichten
>> an den Absender nicht für fristgebundene Mitteilungen geeignet sind.
>> Fristgebundene Mitteilungen sind daher ausschließlich per Post oder per
>> Telefax zu übersenden.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130911/8b1d975b/attachment.html>
