[postgis-users] Unable to pass the configure step on HP-UX 11.23
Sandro Santilli
strk at keybit.net
Fri Sep 13 06:33:23 PDT 2013
On Fri, Sep 13, 2013 at 03:09:17PM +0200, VEYSSIERE Nicolas wrote:
> Today I have opened a ticket for geos on HP-UX 11.23 ia64 (http://trac.osgeo.org/geos/ticket/664).
> I have submitted this patch, because I want to build Postgis on the same platform.
> But as a someone before me (http://lists.osgeo.org/pipermail/postgis-users/2011-February/028847.html) I am unable to pass the configure step on the test for the initGEOS function.
> ./configure
> checking for initGEOS in -lgeos_c... no
> When I search to find the problem, it failed to build the conftest program that test the initGEOS function :
> gcc -o conftest conftest.c -lgeos_c -L/usr/local/lib
> ld: Unsatisfied symbol "geos::geom::GeometryFactory::createPoint(geos::geom::CoordinateSequence*) const" in file /usr/local/lib/libgeos_c.a[libgeos_c_la-geos_ts_c.o]
It looks like the linker is failing to recognize that libgeos_c.so requires
libgeos.so, which is the one containing the actual symbols.
> The problem is that these functions seems to be there :
> nm -C /usr/local/lib/libgeos_c.a | grep "geos::geom::GeometryFactory::createPoint"
> U geos::geom::GeometryFactory::createPoint(geos::geom::CoordinateSequence*) const
> U geos::geom::GeometryFactory::createPoint(geos::geom::Coordinate const&) const
> U geos::geom::GeometryFactory::createPoint() const
It's in the static library, but not in the dynamic one.
Can it be a bug in the way geos was built ?
Did "make check" for geos work fine ?
Does any other libgeos user application work fine ?
--strk;
