[postgis-users] curves geometries and topology
Sandro Santilli
strk at keybit.net
Tue Apr 15 07:58:44 PDT 2014
On Tue, Apr 15, 2014 at 04:40:34PM +0200, Reijer Copier wrote:
> Thanks!
> We are currently considering using PostGIS Topology only to maintain
> a topology aware copy of the data (to be used for analyses where
> topology matters) and use the original geometry (containing circular
> strings) when we have to (re)generate output geometry.
> BTW: Is cgal/sfcgal going to replace geos eventually? It would be
> great if this limitation (= curved geometries being a second class
> citizen) was somehow lifted in future versions PostGIS.
It could be, once it gets to support everything currently supported
by the GEOS backend and proves to be better maintained :)
--strk;
