[postgis-users] shp2pgsql
Rémi Cura
remi.cura at gmail.com
Wed Apr 16 06:41:09 PDT 2014
Command options :
http://www.bostongis.com/pgsql2shp_shp2pgsql_quickguide_20.bqg
The schema is specified in the same time as table name.
Regarding the database, you have to specify it when using psql with the
"-d" option
You can also do this in one step using the shp2pgsql-gui .
Cheers,
Rémi-C
2014-04-16 14:23 GMT+02:00 Rogério <rtaguat at gmail.com>:
> Hi,
> How I convert a shp file to sql pointing to a particular schema and
> database?
> As the trivial operation of converting shp to sql is ok!
> Is possible?
> Thanks!
> Rogério A. B. da Silva
> Geóg. B. Sc.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140416/759f4bb1/attachment.html>
