[postgis-users] raster2pgsql 2.1.1 on Windows 7 64bit - ERREUR: erreur de syntaxe
droletguillaume
droletguillaume at gmail.com
Wed Apr 16 20:24:44 PDT 2014
Sent from Samsung Mobile
The problem I have is similar to this one from an old thread on this list:
https://www.mail-archive.com/postgis-users@lists.osgeo.org/msg00013.html
I have never succeeded to load a raster into PostGIS on my machine. In
the past, I have experienced the same type of error as the one presented in that old thread above when trying to load rasters, mainly TIF files.
Today, I tried once again, thinking that my new version of PostGIS (2.1.1) would solve the problem but no luck...
When I run this command:
E:\data\>raster2pgsql -s 4326 -d -M -I -C -R -F -t 50x50
MOD15A2.A2000049.h12v04.005.2
006268184934_Lai_1km.tif modis.temp | psql -d mortalite -U postgres
I get this:
<several lines of INSERT 0 1>
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
CREATE INDEX
ANALYZE
ERREUR: erreur de syntaxe à la fin de l'entrée
LINE 1: SELECT AddRasterConstraints('modis','temp'
If I redirect the output of raster2pgsql to an SQL file, I can see that the last line of the file is incomplete, which causes the error:
INSERT INTO "modis"."temp" ("rast","filename") VALUES
('0100000100F69DBA4D1311813FF69DBA4D131181BF67341363EC7752C06392AE819989474000000000000000000000000000000000E610000032002A008700000000004D4F44313541322E41323030303034392E6831327630342E3030352E323030363236383138343933345F4C61695F316B6D2E74696600'::raster,'MOD15A2.A2000049.h12v04.005.2006268184934_Lai_1km.tif');
('0100000100F69DBA4D1311813FF69DBA4D131181BFD0C0E9B4415D52C06392AE819989474000000000000000000000000000000000E610000032002A008700000000004D4F44313541322E41323030303034392E6831327630342E3030352E323030363236383138343933345F4C61695F316B6D2E74696600'::raster,'MOD15A2.A2000049.h12v04.005.2006268184934_Lai_1km.tif');
('0100000100F69DBA4D1311813FF69DBA4D131181BFA3D99658EC2752C06392AE819989474000000000000000000000000000000000E610000019002A008700000000004D4F44313541322E41323030303034392E6831327630342E3030352E323030363236383138343933345F4C61695F316B6D2E74696600'::raster,'MOD15A2.A2000049.h12v04.005.2006268184934_Lai_1km.tif');
CREATE INDEX "temp_rast_gist" ON "modis"."temp" USING gist
(st_convexhull("rast"));
ANALYZE "modis"."temp";
This is very frustrating as since 2012, we've never been able to use any
raster in PostGIS :(
Has anyone ever experienced similar problems?
Thanks for helping,
Guillaume
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140416/cd60d656/attachment.html>
