[postgis-users] raster2pgsql 2.1.1 on Windows 7 64bit - ERREUR: erreur de syntaxe
Rémi Cura remi.cura at gmail.com
Thu Apr 17 00:50:29 PDT 2014
Hey,
It may be unrelated, but have you checked your gdal version?
Another question, may it be encoding related (any special character, space
etc in file name ?)
Cheers,
Rémi-C
2014-04-17 5:24 GMT+02:00 droletguillaume <droletguillaume at gmail.com>:
> Sent from Samsung Mobile
> Hi,
> The problem I have is similar to this one from an old thread on this list:
> https://www.mail-archive.com/postgis-users@lists.osgeo.org/msg00013.html
> I have never succeeded to load a raster into PostGIS on my machine. In
> the past, I have experienced the same type of error as the one presented
> in that old thread above when trying to load rasters,  mainly TIF files.
> Today, I tried once again, thinking that my new version of PostGIS (2.1.1)
> would solve the problem but no luck...
> When I run this command:
> E:\data\>raster2pgsql -s 4326 -d -M -I -C -R -F -t 50x50
> MOD15A2.A2000049.h12v04.005.2
> 006268184934_Lai_1km.tif modis.temp | psql -d mortalite -U postgres
> I get this:
> <several lines of INSERT 0 1>
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> CREATE INDEX
> ANALYZE
> ERREUR:  erreur de syntaxe à la fin de l'entrée
> LINE 1: SELECT AddRasterConstraints('modis','temp'
> If I redirect the output of raster2pgsql to an SQL file, I can see that
> the last line of the file is incomplete, which causes the error:
> INSERT INTO "modis"."temp" ("rast","filename") VALUES
> ('0100000100F69DBA4D1311813FF69DBA4D131181BF67341363EC7752C06392AE819989474000000000000000000000000000000000E610000032002A008700000000004D4F44313541322E41323030303034392E6831327630342E3030352E323030363236383138343933345F4C61695F316B6D2E74696600'::raster,'MOD15A2.A2000049.h12v04.005.2006268184934_Lai_1km.tif');
> ('0100000100F69DBA4D1311813FF69DBA4D131181BFD0C0E9B4415D52C06392AE819989474000000000000000000000000000000000E610000032002A008700000000004D4F44313541322E41323030303034392E6831327630342E3030352E323030363236383138343933345F4C61695F316B6D2E74696600'::raster,'MOD15A2.A2000049.h12v04.005.2006268184934_Lai_1km.tif');
> ('0100000100F69DBA4D1311813FF69DBA4D131181BFA3D99658EC2752C06392AE819989474000000000000000000000000000000000E610000019002A008700000000004D4F44313541322E41323030303034392E6831327630342E3030352E323030363236383138343933345F4C61695F316B6D2E74696600'::raster,'MOD15A2.A2000049.h12v04.005.2006268184934_Lai_1km.tif');
> CREATE INDEX "temp_rast_gist" ON "modis"."temp" USING gist
> (st_convexhull("rast"));
> ANALYZE "modis"."temp";
> This is very frustrating as since 2012, we've never been able to use any
> raster in PostGIS :(
> Has anyone ever experienced similar problems?
> Thanks for helping,
> Guillaume
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140417/bf47bb96/attachment.html>
