[postgis-users] Better storage strategy for 1 million tile of 50*50 pixels, 24 bands?
Rémi Cura
remi.cura at gmail.com
Thu Apr 17 09:07:50 PDT 2014
Hey,
from what I tried PostGis Raster is (relatively) slow and not adapted to
multi bands
(for instance, no way to set multiple bands at once. For my use case this
would mean about 300k*0.1sec i.e. about 8 hours at best).
The GDAL driver + QGIS should be considered an experimental function at the
moment,
because it is still easily broken (and I'm speaking cutting edge gdal +
qgis v 2, 2.2, 2.3 on win and linux).
More generaly using QGIS with postgis is easily broken (i restart qgis
several dozen times a day)
Taking that into consideration,
My conclusion is that for the moment there is no incentive to use __in
base__ postgis raster,
because there is no stable way to access raster from outside base.
Sadly in my general use case, this translate to no incentive to use postgis
raster at all :-(
Cheers,
Rémi-C
2014-04-17 17:43 GMT+02:00 Tumasgiu Rossini <rossini.t at gmail.com>:
> Remi,
> I'm interested in the way you handled this problem.
> In my opinion, the problem is on the duality of your needs.
> Out-db is known to be faster for visualisation.
> In-db is better for analysis.
> So, a compromise should be made Maybe storing each tile per "band type" ?
> So accessing data from qgis would be less painful ?
> 2014-03-10 10:54 GMT+01:00 Rémi Cura <remi.cura at gmail.com>:
>> Hey Dear List,
>> I would appreciate some advice about the best way to store my raster :
>> 1 million tiles,
>> 50*50 pixels each (1 m2 or less in real world), around 24 bands (mostly
>> doubles)
>> ,in db.
>> About half the pixels are empty, some tiles overlaps, but most are
>> regularly spaced.
>> I would query it mainly by localisation (intersects), and also based on
>> id of the tile.
>> The use would be fast visualisation with qgis (and latest gdal),
>> interpolation, classification, matching and so.
>> What is the best strategy?
>> 1 table with many lines and indexes, indb,
>> 1 table, out db
>> 1 table, 1 line
>> multiple tables, heritage?
>> Thanks for inputs!
>> Cheers,
>> Rémi-C
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140417/91ceff06/attachment.html>
