[postgis-users] TIGER geocoder
Andre Mano andre.s.mano at gmail.com
Thu Apr 17 11:39:39 PDT 2014
Thank you for your report.
I followed your suggestions but I run into one more question.
The readme file that documents the geocoder tool says it's necessary to
"Create a folder called gisdata on root of server or your local pc".
What is considered to be the root of the server? The directory where
Postgres is installed?
Thank you for your support,
Andre
On Thu, Apr 17, 2014 at 10:37 AM, Paragon Corporation <lr at pcorp.us> wrote:
>  Andre,
> If you plan to do geocoding, then you need to load tiger data.  Next steps
> here:
> http://postgis.net/docs/manual-2.1/postgis_installation.html#tiger_geocoder_loading_data
> Hope that helps,
> Regina
> http://www.postgis.us
> http://postgis.net
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Andre Mano
> *Sent:* Wednesday, April 16, 2014 7:22 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] TIGER geocoder
>  Hi users,
> I am a bit lost on the necessary steps in order to use the TIGER geocoding
> tool. This is what I have done so far:
>  # Enable geocoding capabilities
> CREATE EXTENSION fuzzystrmatch;
> CREATE EXTENSION postgis_tiger_geocoder;
> # Test Geocoding capabilities
> SELECT na.address, na.streetname,na.streettypeabbrev, na.zip
> FROM normalize_address('1 Devonshire Place, Boston, MA 02109') AS na;
> (Returns, as expected: 1;"Devonshire";"Pl";"02109")
> But now I don't know exactly what I have to do. I have read the
> documentation, but still I am not very secure of what I should do. Does
> anyone here with experience with the TIGER geocoder can give me a hint?
> (PostgresSQL 9.3, PostGIS 2.1, Win7 Enterprise 64bits)
> Thank you,
> Andre
> André Mano
> http://opussig.blogspot.com/
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
André Mano
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140417/8a8415fd/attachment.html>
