[postgis-users] TIGER geocoder
Paragon Corporation
lr at pcorp.us
Thu Apr 17 11:59:03 PDT 2014
No not directory where Postgres is installed.
On Windows something like C:\gisdata or E:\gisdata
On Linux /gisdata
Technically you can create the folder anywhere as long as you change the
path in the generated script (or prechange it in the
tiger.loader_variables.staging_fold field before you generate the script) to
where you want the files put.
Note that if you put the folder on your local pc and your PostgreSQL server
is on another machine, you'll need to have shp2pgsql and psql executables
etc accessible from your local pc.
It's generally more efficient to just run from the machine you have
PostgreSQL installed because of network / bandwidth.
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
_____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Andre Mano
Sent: Thursday, April 17, 2014 2:40 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] TIGER geocoder
Thank you for your report.
I followed your suggestions but I run into one more question.
The readme file that documents the geocoder tool says it's necessary to
"Create a folder called gisdata on root of server or your local pc".
What is considered to be the root of the server? The directory where
Postgres is installed?
Thank you for your support,
Andre
On Thu, Apr 17, 2014 at 10:37 AM, Paragon Corporation <lr at pcorp.us> wrote:
Andre,
If you plan to do geocoding, then you need to load tiger data. Next steps
here:
http://postgis.net/docs/manual-2.1/postgis_installation.html#tiger_geocoder_
loading_data
Hope that helps,
Regina
h <http://www.postgis.us> ttp://www.postgis.us
h <http://postgis.net> ttp://postgis.net
_____
Sent: Wednesday, April 16, 2014 7:22 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] TIGER geocoder
Hi users,
I am a bit lost on the necessary steps in order to use the TIGER geocoding
tool. This is what I have done so far:
# Enable geocoding capabilities
CREATE EXTENSION fuzzystrmatch;
CREATE EXTENSION postgis_tiger_geocoder;
# Test Geocoding capabilities
SELECT na.address, na.streetname,na.streettypeabbrev, na.zip
FROM normalize_address('1 Devonshire Place, Boston, MA 02109') AS na;
(Returns, as expected: 1;"Devonshire";"Pl";"02109")
But now I don't know exactly what I have to do. I have read the
documentation, but still I am not very secure of what I should do. Does
anyone here with experience with the TIGER geocoder can give me a hint?
(PostgresSQL 9.3, PostGIS 2.1, Win7 Enterprise 64bits)
Thank you,
Andre
André Mano
<http://opussig.blogspot.com/> http://opussig.blogspot.com/
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
André Mano
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140417/13d02970/attachment.html>
