[postgis-users] ArcGIS issue - specified coordinate exceeds the valid coordinate range
Sandro Santilli
strk at keybit.net
Fri Apr 18 07:54:45 PDT 2014
On Fri, Apr 18, 2014 at 12:53:01PM +0000, Mark Volz wrote:
> Hello,
> I am able to access PostGIS layers on AutoCAD map. However, ArcGIS is reporting an error "The selected object failed to draw database.public.layer: The specified coordinate exceeds the valid coordinate range. What steps would I need to do to fix this?
Stop using AutoCAD map and ArcGIS and be free again ?
--strk;
