[postgis-users] ArcGIS issue - specified coordinate exceeds the valid coordinate range
Bborie Park
dustymugs at gmail.com
Fri Apr 18 08:11:16 PDT 2014
Mark,
You'll need to provide a lot more information about your layer. Saying that
the layer works in one application but not another does not help much.
You should inspect the geometries of your layer to see if one of them has a
coordinate exceeding the valid range. For example, if your geometries were
in WGS84, we would expect all coordinates to be between -180 - 180 and -90
- 90. If a coordinate was -181, 54, that would throw the range error.
-bborie
On Fri, Apr 18, 2014 at 5:53 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I am able to access PostGIS layers on AutoCAD map. However, ArcGIS is
> reporting an error “The selected object failed to draw
> database.public.layer: The specified coordinate exceeds the valid
> coordinate range. What steps would I need to do to fix this?
> Sincerely,
> Mark Volz
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140418/db4eb7ed/attachment.html>
