[postgis-users] PSC/Development Vote -- Baris to release upcoming 2.1.3 jars and manually sign
Paragon Corporation lr at pcorp.us
Sat Apr 19 17:47:16 PDT 2014
Baris,
Regarding this:
> Here is my proposal: I can take care of the last  targeted 2.1 release
which is 2.1.3 and change pom.xmls as I did in the trunk and apply shanes
patches and after the release of 2.1.3 I can manually sign the jars and
submit them to OSSRH. And keep discussing the separation of
> repositories on trunk.
+1 for that.  Others in PSC and development please vote on this as well so
we can start moving on this.
I think we'll be releasing a 2.1.3 fairly soon.  2.2.0 we are looking at at
least another 4 months and that's being hopeful :)
Thanks,
Regina
http://www.postgis.us
http://postgis.net
  _____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Baris Ergun
Sent: Saturday, April 19, 2014 4:50 AM
To: PostGIS Users Discussion
Cc: PostGIS Development Discussion
Subject: Re: [postgis-users] [postgis-devel] looking for a public well known
maven repository for postgis-jdbc 2.1 and later on versions
Hi Shane;
People are busy with other stuff so until we decide to separate the
repositories for postgis java projects I have applied ur patches to both
jdbc and jdbc_jtsparser projects. So what this means is "when we release
2.2.0 postgis I would be ready to submit these two jars manually to OSSRH".
Baris
On 7 April 2014 21:26, Shane StClair <shane at axiomalaska.com> wrote:
Hi Baris,
Oops, I didn't see that you were already chasing this down. Your approach
sounds great, thanks for taking the lead on this! In the past there have
been issues with other projects having non-resolvable dependencies on
versions of postgis-jdbc (Hibernate Spatial), so it will be great to have
these artifacts in the central repo.
Best,
Shane
On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com> wrote:
Hi Shane;
Thanks for ur patch and consideration. I think we are on the same path if u
check the issue #2626. I have applied the OSSRH and got the credentials for
being able to upload postgis jdbc jars to central maven rep. For that case I
have separated the jdbc and jdbc-jtsparser jars on the trunk and updated the
pom.xml's according to Central maven repository requirements.. On the trunk
actually I was waiting to agree  with all the developers to separate the
postgis jdbc jars  repository and continue with 1st suggested approach.  If
we do that way we wouldnt need to make the explicit plugin declarations as
you patched in 2702.
Here is my proposal: I can take care of the last  targeted 2.1 release which
is 2.1.3 and change pom.xmls as I did in the trunk and apply shanes patches
and after the release of 2.1.3 I can manually sign the jars and submit them
to OSSRH. And keep discussing the separation of repositories on trunk.
On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
I don't have any objections.  +1 for that.
Thanks,
Regina
  _____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shane StClair
Sent: Saturday, April 05, 2014 5:24 PM
Subject: Re: [postgis-users] looking for a public well known maven
Sounds good. Any objection to the community manually uploading pre-2.2
versions to Maven Central?
Thanks,
Shane
On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us> wrote:
Shane,
I think we can change our build bot to upload to maven as part of the
official release job when we build tagged docs etc.  Have to talk over with
rest of PostGIS psc and dev folks on that.
I guess before that we'll need to completely cleanup the issues with our
current jdbc which sounds like we are close.  Thanks for the patch BTW.
Thanks,
Regina Obe
PostGIS PSC member
http://postgis.net
  _____
Sent: Saturday, April 05, 2014 3:29 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] looking for a public well known maven repository
I just submitted a patch [1] to generate javadoc and source jars as part of
the postgis-jdbc build. Otherwise, the existing pom meets the Maven Central
sync requirements [2].
There are two options for getting up to date postgis-jdbc releases into
Maven Central. The first would be for Maven Central deployment to become
part of the postgis release process. After the initial setup the Maven
Central publishing process isn't terribly painful, but it would require a
postgis developer to assume responsibility for the Maven Central submission
and for postgis-jdbc to get special consideration during releases [3] [4].
The other option would be to have the community manually upload to Maven
Central [5]. This is definitely not the ideal situation, but if Maven
Central uploads are out of scope for the postgis devs right now it would
allow us to get updated versions into the central repo. A blessing from the
postgis devs would help in this second case.
Thanks,
Shane
[1] http://trac.osgeo.org/postgis/ticket/2702
[2] https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
[3]
https://maven.apache.org/guides/mini/guide-central-repository-upload.html
[4] http://central.sonatype.org/pages/ossrh-guide.html
[5]
https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+t
o+The+Central+Repository
Shane StClair
Software Engineer
Axiom Consulting & Design
http://www.axiomalaska.com
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Shane StClair
Software Engineer
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Barış
Shane StClair
Software Engineer
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140419/26dbd3c7/attachment.html>
