[postgis-users] [postgis-devel] PSC/Development Vote -- Baris to release upcoming 2.1.3 jars and manually sign
Bborie Park
dustymugs at gmail.com
Sat Apr 19 17:52:46 PDT 2014
+1 for release of 2.1.3 jar.
On Sat, Apr 19, 2014 at 5:47 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Baris,
> Regarding this:
> > Here is my proposal: I can take care of the last targeted 2.1 release
> which is 2.1.3 and change pom.xmls as I did in the trunk and apply shanes
> patches and after the release of 2.1.3 I can manually sign the jars and
> submit them to OSSRH. And keep discussing the separation of
> > repositories on trunk.
> +1 for that. Others in PSC and development please vote on this as well so
> we can start moving on this.
> I think we'll be releasing a 2.1.3 fairly soon. 2.2.0 we are looking at
> at least another 4 months and that's being hopeful :)
> Thanks,
> Regina
> http://www.postgis.us
> http://postgis.net
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Baris Ergun
> *Sent:* Saturday, April 19, 2014 4:50 AM
> *To:* PostGIS Users Discussion
> *Cc:* PostGIS Development Discussion
> *Subject:* Re: [postgis-users] [postgis-devel] looking for a public well
> known maven repository for postgis-jdbc 2.1 and later on versions
> Hi Shane;
> People are busy with other stuff so until we decide to separate the
> repositories for postgis java projects I have applied ur patches to both
> jdbc and jdbc_jtsparser projects. So what this means is "when we release
> 2.2.0 postgis I would be ready to submit these two jars manually to OSSRH".
> Baris
> On 7 April 2014 21:26, Shane StClair <shane at axiomalaska.com> wrote:
>> Hi Baris,
>> Oops, I didn't see that you were already chasing this down. Your approach
>> sounds great, thanks for taking the lead on this! In the past there have
>> been issues with other projects having non-resolvable dependencies on
>> versions of postgis-jdbc (Hibernate Spatial), so it will be great to have
>> these artifacts in the central repo.
>> Best,
>> Shane
>> On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com>wrote:
>>> Hi Shane;
>>> Thanks for ur patch and consideration. I think we are on the same path
>>> if u check the issue #2626. I have applied the OSSRH and got the
>>> credentials for being able to upload postgis jdbc jars to central maven
>>> rep. For that case I have separated the jdbc and jdbc-jtsparser jars on the
>>> trunk and updated the pom.xml's according to Central maven repository
>>> requirements.. On the trunk actually I was waiting to agree with all the
>>> developers to separate the postgis jdbc jars repository and continue with
>>> 1st suggested approach. If we do that way we wouldnt need to make the
>>> explicit plugin declarations as you patched in 2702.
>>> submit them to OSSRH. And keep discussing the separation of repositories on
>>> trunk.
>>> On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
>>>> I don't have any objections. +1 for that.
>>>> Thanks,
>>>> Regina
>>>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Shane StClair
>>>> *Sent:* Saturday, April 05, 2014 5:24 PM
>>>> *Subject:* Re: [postgis-users] looking for a public well known maven
>>>> Sounds good. Any objection to the community manually uploading
>>>> pre-2.2 versions to Maven Central?
>>>> Thanks,
>>>> Shane
>>>> On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us>wrote:
>>>>> Shane,
>>>>> I think we can change our build bot to upload to maven as part of the
>>>>> official release job when we build tagged docs etc. Have to talk over with
>>>>> rest of PostGIS psc and dev folks on that.
>>>>> I guess before that we'll need to completely cleanup the issues with
>>>>> our current jdbc which sounds like we are close. Thanks for the patch BTW.
>>>>> Thanks,
>>>>> Regina Obe
>>>>> PostGIS PSC member
>>>>> http://postgis.net
>>>>> *Sent:* Saturday, April 05, 2014 3:29 PM
>>>>> *To:* postgis-users at lists.osgeo.org
>>>>> *Subject:* [postgis-users] looking for a public well known maven
>>>>> I just submitted a patch [1] to generate javadoc and source jars as
>>>>> part of the postgis-jdbc build. Otherwise, the existing pom meets the Maven
>>>>> Central sync requirements [2].
>>>>> There are two options for getting up to date postgis-jdbc releases
>>>>> into Maven Central. The first would be for Maven Central deployment to
>>>>> become part of the postgis release process. After the initial setup the
>>>>> Maven Central publishing process isn't terribly painful, but it would
>>>>> require a postgis developer to assume responsibility for the Maven Central
>>>>> submission and for postgis-jdbc to get special consideration during
>>>>> releases [3] [4].
>>>>> The other option would be to have the community manually upload to
>>>>> Maven Central [5]. This is definitely not the ideal situation, but if Maven
>>>>> Central uploads are out of scope for the postgis devs right now it would
>>>>> allow us to get updated versions into the central repo. A blessing from the
>>>>> postgis devs would help in this second case.
>>>>> Thanks,
>>>>> Shane
>>>>> [1] http://trac.osgeo.org/postgis/ticket/2702
>>>>> [2]
>>>>> https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
>>>>> [3]
>>>>> https://maven.apache.org/guides/mini/guide-central-repository-upload.html
>>>>> [4] http://central.sonatype.org/pages/ossrh-guide.html
>>>>> [5]
>>>>> https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+to+The+Central+Repository
>>>>> Shane StClair
>>>>> Software Engineer
>>>>> Axiom Consulting & Design
>>>>> http://www.axiomalaska.com
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>> Shane StClair
>>>> Software Engineer
>>>> postgis-devel mailing list
>>>> postgis-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>>> Barış
>> Shane StClair
>> Software Engineer
> Barış
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140419/63b0aaa2/attachment.html>
