[postgis-users] Error installing postgis 2.1.2 on postgresql 9.2.8 on solaris 10 (x86)
Phillip Ross
phillip.w.g.ross+postgis-users at gmail.com
Tue Apr 22 12:03:15 PDT 2014
Hi Kedar, the following are the steps that I use:
wget http://download.osgeo.org/postgis/source/postgis-2.1.2.tar.gz
tar xvfz postgis-2.1.2.tar.gz
cd postgis-2.1.2
gpatch -p1 < ../postgis-2.1.2-use-finite-instead-of-isfinite-for-solaris.patch
Hope that helps!
On Tue, Apr 22, 2014 at 2:44 PM, Tambade, Kedar <ktambade at cghtech.com> wrote:
> Phillip,
> Thank you for the patch.
> I was trying to apply the patch in the following way:
> gtar xvzf postgis-2.1.1.tar.gz && patch –b –p0 <
> But, after the files are untarred it prompts for the file names to be
> patched what file name should I give. Following is the prompt that I get:
> Looks like a unified context diff.
> File to patch:
> Thanks & Regards,
> Kedar
> This electronic mail message and any attached files contain information
> intended for the exclusive use of the individual or entity to whom it is
> addressed and may contain information that is propriety, privileged,
> confidential and/or exempt from disclosure under applicable law. If you are
> not the intended recipient, you are hereby notified that any viewing,
> copying, disclosure or distribution of this information may be subject to
> legal restriction or sanction. Please notify the sender, by electronic mail
> or telephone, of any unintended recipients and delete the original message
> without making any copies.
> From: postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Phillip Ross
> Sent: Monday, April 21, 2014 9:05 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Error installing postgis 2.1.2 on postgresql
> Hi Kedar...
> I had a similar issue with Solaris 11. I think the config scripts need some
> work to properly detect the isfinite situation with Solaris environments.
> I've not had the time to work through the config scripts, but I'll attach
> the patch that I use to get it to build on solaris 11. This might also work
> on solaris 10.
> Also, I'm not sure what the implications of doing it this way are, but it
> seems to be stable for my environments thus far.
> Hope it helps!
> - Phillip
> On Mon, Apr 21, 2014 at 4:39 PM, Tambade, Kedar <ktambade at cghtech.com>
> wrote:
> Thank you Strk for the quick response... Following are the answers to your
> question
> Does your libm have "isfinite" ?
> No, " nm -D /usr/lib/libm.so | grep -i isfinite" did not return any result.
> what's available function/macro to check for finiteness ?
> did not understand what should I check, can you please let me know what
> exactly should I check.
> Note that ./configure script should be checking for isfinite, defining or
> not a HAVE_ISFINITE macro in postgis/postgis_config.h What does it say ?
> Postgis/postgis_config.h file does not contain HAVE_ISFINITE.
> Thanks & Regards,
> Kedar Tambade
> -----Original Message-----
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
> Sent: Friday, April 18, 2014 10:53 AM
> On Thu, Apr 17, 2014 at 07:12:13PM +0000, Tambade, Kedar wrote:
>> Hello all,
>> While installating the postgis 2.1.2 on solaris 10 (5.10 Generic_147441-05
>> i86pc i386 i86pc), I am getting the following error while doing gmake can
>> someone please help :
>> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
>> -I../rt_core -I../../liblwgeom -I/opt/postgres/gis928/include
>> -I/opt/postgres/gis928/include -I/opt/postgres/gis928/include raster2pgsql.o
>> -o .libs/raster2pgsql ../rt_core/librtcore.a -L/opt/postgres/gis928/lib
>> ../../liblwgeom/.libs/liblwgeom.so -L/usr/sfw/lib
>> /opt/postgres/gis928/lib/libproj.so /opt/postgres/gis928/lib/libjson.so
>> /opt/postgres/gis928/lib/libgdal.so -L/usr/lib -L/usr/local/lib
>> -L/usr/openwin/lib -L/usr/local/ssl/lib -L/usr/X11R6/lib
>> -L/usr/local/BerkeleyDB.4.7/lib -L/usr/local/mysql/lib -lpq -lrt -ldl -lxml2
>> -lz -lpthread -lsocket -lnsl /opt/postgres/gis928/lib/libgeos_c.so
>> /opt/postgres/gis928/lib/libgeos.so /usr/sfw/lib/libstdc++.so -lgcc_s
>> /usr/local/lib/libiconv.so -lm -R/usr/local/lib -R/opt/postgres/gis928/lib
>> -R/usr/sfw/lib -R/usr/lib
>> Undefined first referenced
>> symbol in file
>> isfinite ../../liblwgeom/.libs/liblwgeom.so
>> ld: fatal: symbol referencing errors. No output written to
>> .libs/raster2pgsql
>> collect2: ld returned 1 exit status
>> gmake[2]: *** [raster2pgsql] Error 1
>> gmake[2]: Leaving directory
>> `/opt/postgres/repository/postgresql_9.2.8/postgis-2.1.2/raster/loader'
>> following is the gcc version:
>> $ gcc --version
>> gcc (GCC) 3.4.3 (csl-sol210-3_4-branch+sol_rpath) Copyright (C) 2004
>> Free Software Foundation, Inc.
>> This is free software; see the source for copying conditions. There
>> is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
>> PURPOSE.
> Or what's available function/macro to check for finiteness ?
> Then there's code around the codebase using that macro to do different
> thing. Take a look. Patch is welcome once you figure out.
> --strk;
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
