[postgis-users] Rép: Re: Rép: Re: Grouping by geom with count?
Hugues François
hugues.francois at irstea.fr
Thu Apr 24 08:44:07 PDT 2014
Instead of a.the_geom != b.the_geom you should write not st_equals(a.the_geom,b.the_geom).
Hug
James David Smith <james.david.smith at gmail.com> a écrit :
No problem. I'm not quite sure how to work that into the query though please?
On 24 April 2014 16:27, Hugues François <hugues.francois at irstea.fr> wrote:
> Excuse me for the mistake. Let's try st_equals.
> Hug
> Thanks for the reply Hugues. Much appreciated. I've replaced the
> various bit of the query with my own table names etc, but get an
> error. Any thoughts/ideas guys?
> ERROR: operator is not unique: geometry <> geometry
> LINE 15: WHERE a.ssid=b.ssid and a.the_geom != b.the_geom
> WITH inter AS (
> SELECT DISTINCT a.ssid,
> ST_CollectionExtract(st_intersection(a.the_geom, b.the_geom),2)
> the_geom
> FROM stage a, stage b
> WHERE st_intersects(a.the_geom, b.the_geom)
> inter_line AS (
> SELECT ssid, ST_UNION (the_geom) the_geom
> FROM inter
> GROUP BY ssid),
> diff_line AS (
> SELECT a.ssid,
> st_union(st_collectionextract(st_difference(a.the_geom,
> b.the_geom),2)) the_geom
> FROM stage a, inter_line b
> GROUP BY a.ssid
> all_lines AS (
> SELECT * FROM inter_line
> UNION ALL
> SELECT * FROM diff_line
> SELECT the_geom, count(*) FROM all_lines
> GROUP BY the_geom
> On 24 April 2014 11:37, Hugues François <hugues.francois at irstea.fr> wrote:
>> Hello,
>> I think the use of st_intersection / st_difference may help you to achieve that you will have to take care of duplicates. I think the query could be something like the first draft below but could be improved. The principle is to find intersections from geometry from a self join of your original table and use this output to get the difference with your original table. Maybe someone else will have a better idea !
>> HTH
>> Hug
>> WITH inter AS (
>> SELECT DISTINCT a.gid, ST_CollectionExtract(st_intersection(a.geom, b.geom),2) geom
>> FROM yourtable a, yourtable b
>> WHERE st_intersects(a.geom, b.geom)
>> inter_line AS (
>> SELECT gid, ST_UNION (geom) geom
>> FROM line_inter
>> GROUP BY gid),
>> diff_line AS (
>> SELECT a.gid, st_union(st_collectionextract(st_difference(a.geom, b.geom),2)) geom
>> FROM yourtable a, inter_line b
>> WHERE a.gid=b.gid and a.geom != b.geom
>> GROUP BY a.gid
>> all_lines AS (
>> UNION ALL
>> SELECT geom, count(*) FROM all_lines
>> GROUP BY geom
>> -----Message d'origine-----
>> De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de James David Smith
>> Envoyé : jeudi 24 avril 2014 11:11
>> À : PostGIS Users Discussion
>> Objet : [postgis-users] Grouping by geom with count?
>> Hi all,
>> A bit of advice please. I have a table of about 250,000 linestring.
>> They represent peoples routes on roads around London. I would like to use them in QGIS now to show the most used roads by making them a darker colour. So to do this I feel I need to do some sort of grouping of the geometries with a count column too - so that I can use that count column to define the darkness of the line on my map.
>> How could I go about doing this please?
>> The problem I can see in my head is that let's say I have one linestring which goes from A to B. Then another linestring that goes from A to B to C. When I group the geometries, these won't group as they aren't the same. However I would want the result to be that linestring A to B is given a value of 2 and the bit of the line from B to C would be given a value of 1.
>> I think I'm perhaps overcomplicating this...
>> Thanks
>> James
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
