[postgis-users] how to convert GeometryCollection to multipolygon shape
Rémi Cura
remi.cura at gmail.com
Sun Apr 27 07:18:08 PDT 2014
SELECT ST_CollectionExtract(geom,3)<http://postgis.refractions.net/docs/ST_CollectionExtract.html>AS
geom
FROM your_table_with_mixed_geometry<http://postgis.refractions.net/docs/ST_CollectionExtract.html>
It will not change polygon or multi polygon, but will extract it from
geometry collection.
CHeers,
Rémi-C
2014-04-25 19:40 GMT+02:00 <islanis at infomed.sld.cu>:
> islanis at infomed.sld.cu escribió:
> "Rémi Cura" <remi.cura at gmail.com> escribió:
>> But what I want is to homogenize an entire layer, for example, a layer
>> containing both multipolygons and collections, bring all components of this
>> layer to multipolygons.
>> something like this is that i want.
>> Hey,
>>> have a look at ST_CollectionExctract.
>>> Cheers,
>>> Rémi-C
>> How can i use it, please give an exmaple
>>> 2014-04-25 19:08 GMT+02:00 <islanis at infomed.sld.cu>:
>>> Hi people i need help in converting a shape that have a
>>>> GeometryCollection
>>>> data to a multipolygon shape, at least a routine or a function that do
>>>> that.
>>>> thanks
>>>> This message was sent using IMP, the Internet Messaging Program.
>>>> Este mensaje le ha llegado mediante el servicio de correo electronico
>>>> que
>>>> ofrece Infomed para respaldar el cumplimiento de las misiones del
>>>> Sistema
>>>> Nacional de Salud. La persona que envia este correo asume el compromiso
>>>> de
>>>> usar el servicio a tales fines y cumplir con las regulaciones
>>>> establecidas
>>>> Infomed: http://www.sld.cu/
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Este mensaje le ha llegado mediante el servicio de correo electronico que
>> ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema
>> Nacional de Salud. La persona que envia este correo asume el compromiso de
>> usar el servicio a tales fines y cumplir con las regulaciones establecidas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140427/470712a3/attachment.html>
