[postgis-users] Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit - ERREUR: erreur de syntaxe
Paragon Corporation lr at pcorp.us
Wed Apr 30 18:24:06 PDT 2014
Guillaume,
It was my understanding that PostGIS only uses the libgdal in the same
folder as raster2pgsql since that would be the first in its path. However it
uses the environment variable for the proj files and so forth.  So I'm still
a bit surprised this is an issue unless those files are vastly different
from 1.10.
When you do
SELECT postgis_full_version();
What does it give for the GDAL version.
If its just a during load problem, I think you can just simply override the
environment variable in your loader batch script
SET GDAL_DATA="C:\Program Files\PostgreSQL\9.3\gdal-data"
Of course this won't fix your running install.  In PostGIS 2.2 we introduced
a PostgreSQL GUC variable to handle this:
http://postgis.net/docs/manual-dev/postgis_gdal_datapath.html
But unfortunately that won't help you for 2.1 and not sure how much that
helps with raster2pgsql anyway since I don't think raster2pgsql makes
connection to Postgres to be able to even see that variable.
What I could do is create a build that uses the newer GDAL to see if that
improves your situation (you can be my test guinea pig :) ).  IN 2.2 I plan
to ship with GDAL 1.11 and probably upgrade next  2.1 to GDAL 1.11 as well
since unfortunately they have to share the same GDAL on same PostgreSQL
install and some people I expect will be running both.
Opinions?
Regina
http://www.postgis.us
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Drolet
Sent: Wednesday, April 30, 2014 4:39 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit
Hi Regina and others:
We found the problem with raster2pgsql! It was my version of GDAL
(1.11dev) that my GDAL environment variable was pointing to that created the
bug. I simply moved my GDAL folder to some other location (without changing
GDAL environment variable) and ran raster2pgsql again so that PostGIS could
use its own GDAL instead. This resulted in a complete (i.e. no broken line
at the end) output SQL file from raster2pgsql.
Since I want to keep using my GDAL version (1.11dev, with all my add-ons
compiled and the version used by other software), this raises the question:
how to force PostGIS to not use the GDAL installation referenced by the GDAL
environment variable but instead use its own GDAL?
Thanks!
G
2014-04-30 15:00 GMT-04:00  <postgis-users-request at lists.osgeo.org>:
> Send postgis-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         postgis-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-users digest..."
> Today's Topics:
>    1. Re: Subject: Re: raster2pgsql 2.1.1 on Windows 7  64bit -
>       ERREUR: erreur de syntaxe (Paragon Corporation)
> Message: 1
> Date: Tue, 29 Apr 2014 18:51:16 -0400
> From: "Paragon Corporation" <lr at pcorp.us>
> To: "'PostGIS Users Discussion'" <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on
> Message-ID: <40C3ECB89B9F4C388A6CE0F390D877C5 at O>
> Content-Type: text/plain;       charset="us-ascii"
> Guillaume,
> Did you say this works fine on your home pc, but not your work one?
> I'm wondering if maybe its some malware or virus checker shutting down
> the execution of raster2pgsql for some reason.
> Have you looked at the windows event viewer to see if it is showing
> any messages?  I recall one time a behind the scenes VMWare virus
> checker kept on deleting some of my Msys files because it thought it
> was hacker ware. No duh. Had to tell sysadmins to exclude the folder from
their checking.
> Hope that helps,
> Regina
> From: postgis-users-bounces at lists.osgeo.org
> Drolet
> Sent: Monday, April 28, 2014 2:30 PM
> 64bit
> Hi Mateusz,
> Thanks for helping. What you suggested, i.e. outputting raster2pgsql
> to an SQL file instead of piping it to psql, I have done already. I
> also posted examples of where the lines are broken in previous post
> (see also Jean-Daniel Sylvain's older post on the same topic).
> It doesn't seem to break on non-ASCII characters. For example, this
> one breaks in the middle of the file name at line 168:
> INSERT INTO "mod09a1.a2000049.h12v04.005.2006268184041_sur_refl_b01"
> ("rast","filename") VALUES
> ('0100000100A544B7031A11713FA544B7031A1171BF86BE196C857752C095AFEE8CEE
> 6E4740
> 00000000000000000000000000000000E610000032001F008700000000004D4F443039
> 41312E
> 41323030303034392E6831327630342E3030352E323030363236383138343034315F73
> 75725F
> 7265666C5F6230312E74696600'::raster,'MOD09A1.A2000049.h12v04.005.20062
> 681840
> 41_sur_refl_b01.tif');
> ('0100000100A544B7031A11713FA544B7031A1171BF59D7C60F306A52C095AFEE8CEE
> 6E4740
> 41312E
> 75725F
> 681840
> ('0100000100A544B7031A11713FA544B7031A1171BF2BF073B3DA5C52C095AFEE8CEE
> 6E4740
> 41312E
> 75725F
> 681840
> Or, this one (same tif file; I only shortened the filename) breaks in
> the middle of a cell (or tile?) representation, still at line 168:
> INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
> 6E4740
> 41312E
> 41323030303034392E7375725F7265666C5F6230312E74696600'::raster,'MOD09A1
> .A2000
> 049.sur_refl_b01.tif');
> INSERT INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
> 6E4740
> 41312E
> .A2000
> 6E4740
> 41312E
> .A2000
> This is VERY frustrating and I hope an answer will be found!
> Guillaume
> Message: 2
> Date: Thu, 24 Apr 2014 21:43:43 +0200
> From: Mateusz ?oskot <mateusz at loskot.net>
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org
> Message-ID:
> <CABUeae-w_cXrPh_jP3oHBKKaqE9sMi+0bG1zdapOcenpXmqW4w at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> On 24 April 2014 21:19, Guillaume Drolet <droletguillaume at gmail.com>
wrote:
>> I tried the same command as in my previous post on my PC at home.
>> It's Windows 7 64bit as well and the cluster has the same locale
>> ('French.Canadian.1252'.) and encoding (UTF8).
>> The command was successful so my work colleague and I, who
>> experiences the same behaviour as the one described previously on
>> this list, suspect that it may be due to some problems or conflict
>> between PostGIS and the hardware (we have similar systems): is this a
>> sensible hypothesis?
> I doubt it. I use raster2pgsql frequently on Windows, since PostGIS
> pre-2.0 and I have never experienced any such issues.
> raster2pgsql is a standalone command line utility that generates SQL
> commands and outputs them to stdout.
> raster2pgsql has no run-time dependency on PostgreSQL or PostGIS.
> First thing to check is: does raster2pgsql generate valid output, if
> redirected to file, does the SQL commands in output file look
> well-formed and complete?
> If not, which SQL lines are broken?
> Do the broken lines correspond to any character data in non-ASCII
encodings?
> For example, check if you run raster2pgsql with -F switch to add
> column with the name of your raster file and the raster file name
> contains characters with French accents, etc.
> I'd suggest, don't use psql.exe or load any data to PostgreSQL until
> you confirm raster2pgsql generates text output with complete
> well-formed and valid SQL commands first.
> Best regards,
> Mateusz  ?oskot, http://mateusz.loskot.net
> End of postgis-users Digest, Vol 146, Issue 28
