[postgis-users] Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit - ERREUR: erreur de syntaxe
Guillaume Drolet
droletguillaume at gmail.com
Wed Apr 30 13:39:28 PDT 2014
Hi Regina and others:
We found the problem with raster2pgsql! It was my version of GDAL
(1.11dev) that my GDAL environment variable was pointing to that
created the bug. I simply moved my GDAL folder to some other location
(without changing GDAL environment variable) and ran raster2pgsql
again so that PostGIS could use its own GDAL instead. This resulted in
a complete (i.e. no broken line at the end) output SQL file from
raster2pgsql.
Since I want to keep using my GDAL version (1.11dev, with all my
add-ons compiled and the version used by other software), this raises
the question: how to force PostGIS to not use the GDAL installation
referenced by the GDAL environment variable but instead use its own
GDAL?
Thanks!
G
2014-04-30 15:00 GMT-04:00 <postgis-users-request at lists.osgeo.org>:
> Send postgis-users mailing list submissions to
> postgis-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> postgis-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-users digest..."
> Today's Topics:
> 1. Re: Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit -
> ERREUR: erreur de syntaxe (Paragon Corporation)
> Message: 1
> Date: Tue, 29 Apr 2014 18:51:16 -0400
> From: "Paragon Corporation" <lr at pcorp.us>
> To: "'PostGIS Users Discussion'" <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on
> Message-ID: <40C3ECB89B9F4C388A6CE0F390D877C5 at O>
> Content-Type: text/plain; charset="us-ascii"
> Guillaume,
> Did you say this works fine on your home pc, but not your work one?
> I'm wondering if maybe its some malware or virus checker shutting down the
> execution of raster2pgsql for some reason.
> Have you looked at the windows event viewer to see if it is showing any
> messages? I recall one time a behind the scenes VMWare virus checker kept
> on deleting some of my Msys files because it thought it was hacker ware. No
> duh. Had to tell sysadmins to exclude the folder from their checking.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Drolet
> Sent: Monday, April 28, 2014 2:30 PM
> To: postgis-users at lists.osgeo.org
> Subject: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit
> Hi Mateusz,
> Thanks for helping. What you suggested, i.e. outputting raster2pgsql to an
> SQL file instead of piping it to psql, I have done already. I also posted
> examples of where the lines are broken in previous post (see also
> Jean-Daniel Sylvain's older post on the same topic).
> It doesn't seem to break on non-ASCII characters. For example, this one
> breaks in the middle of the file name at line 168:
> INSERT INTO "mod09a1.a2000049.h12v04.005.2006268184041_sur_refl_b01"
> ("rast","filename") VALUES
> ('0100000100A544B7031A11713FA544B7031A1171BF86BE196C857752C095AFEE8CEE6E4740
> 00000000000000000000000000000000E610000032001F008700000000004D4F44303941312E
> 41323030303034392E6831327630342E3030352E323030363236383138343034315F7375725F
> 7265666C5F6230312E74696600'::raster,'MOD09A1.A2000049.h12v04.005.20062681840
> 41_sur_refl_b01.tif');
> ('0100000100A544B7031A11713FA544B7031A1171BF59D7C60F306A52C095AFEE8CEE6E4740
> ('0100000100A544B7031A11713FA544B7031A1171BF2BF073B3DA5C52C095AFEE8CEE6E4740
> Or, this one (same tif file; I only shortened the filename) breaks in the
> middle of a cell (or tile?) representation, still at line 168:
> INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
> 41323030303034392E7375725F7265666C5F6230312E74696600'::raster,'MOD09A1.A2000
> 049.sur_refl_b01.tif');
> INSERT INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
> This is VERY frustrating and I hope an answer will be found!
> Guillaume
> Message: 2
> Date: Thu, 24 Apr 2014 21:43:43 +0200
> From: Mateusz ?oskot <mateusz at loskot.net>
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org
> Message-ID:
> <CABUeae-w_cXrPh_jP3oHBKKaqE9sMi+0bG1zdapOcenpXmqW4w at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> On 24 April 2014 21:19, Guillaume Drolet <droletguillaume at gmail.com> wrote:
>> I tried the same command as in my previous post on my PC at home. It's
>> Windows 7 64bit as well and the cluster has the same locale
>> ('French.Canadian.1252'.) and encoding (UTF8).
>> The command was successful so my work colleague and I, who experiences
>> the same behaviour as the one described previously on this list,
>> suspect that it may be due to some problems or conflict between
>> PostGIS and the hardware (we have similar systems): is this a sensible
>> hypothesis?
> I doubt it. I use raster2pgsql frequently on Windows, since PostGIS pre-2.0
> and I have never experienced any such issues.
> raster2pgsql is a standalone command line utility that generates SQL
> commands and outputs them to stdout.
> raster2pgsql has no run-time dependency on PostgreSQL or PostGIS.
> First thing to check is: does raster2pgsql generate valid output, if
> redirected to file, does the SQL commands in output file look well-formed
> and complete?
> If not, which SQL lines are broken?
> Do the broken lines correspond to any character data in non-ASCII encodings?
> For example, check if you run raster2pgsql with -F switch to add column with
> the name of your raster file and the raster file name contains characters
> with French accents, etc.
> I'd suggest, don't use psql.exe or load any data to PostgreSQL until you
> confirm raster2pgsql generates text output with complete well-formed and
> valid SQL commands first.
> Best regards,
> Mateusz ?oskot, http://mateusz.loskot.net
> End of postgis-users Digest, Vol 146, Issue 28
