[postgis-users] Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit - ERREUR: erreur de syntaxe
Paragon Corporation lr at pcorp.us
Tue Apr 29 15:51:16 PDT 2014
Guillaume,
Did you say this works fine on your home pc, but not your work one?
I'm wondering if maybe its some malware or virus checker shutting down the
execution of raster2pgsql for some reason.
Have you looked at the windows event viewer to see if it is showing any
messages?  I recall one time a behind the scenes VMWare virus checker kept
on deleting some of my Msys files because it thought it was hacker ware. No
duh. Had to tell sysadmins to exclude the folder from their checking.
Hope that helps,
Regina
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Drolet
Sent: Monday, April 28, 2014 2:30 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on Windows 7 64bit
Hi Mateusz,
Thanks for helping. What you suggested, i.e. outputting raster2pgsql to an
SQL file instead of piping it to psql, I have done already. I also posted
examples of where the lines are broken in previous post (see also
Jean-Daniel Sylvain's older post on the same topic).
It doesn't seem to break on non-ASCII characters. For example, this one
breaks in the middle of the file name at line 168:
INSERT INTO "mod09a1.a2000049.h12v04.005.2006268184041_sur_refl_b01"
("rast","filename") VALUES
('0100000100A544B7031A11713FA544B7031A1171BF86BE196C857752C095AFEE8CEE6E4740
00000000000000000000000000000000E610000032001F008700000000004D4F44303941312E
41323030303034392E6831327630342E3030352E323030363236383138343034315F7375725F
7265666C5F6230312E74696600'::raster,'MOD09A1.A2000049.h12v04.005.20062681840
41_sur_refl_b01.tif');
('0100000100A544B7031A11713FA544B7031A1171BF59D7C60F306A52C095AFEE8CEE6E4740
('0100000100A544B7031A11713FA544B7031A1171BF2BF073B3DA5C52C095AFEE8CEE6E4740
Or, this one (same tif file; I only shortened the filename) breaks in the
middle of a cell (or tile?) representation, still at line 168:
INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
41323030303034392E7375725F7265666C5F6230312E74696600'::raster,'MOD09A1.A2000
049.sur_refl_b01.tif');
INSERT INTO "mod09a1.a2000049.sur_refl_b01" ("rast","filename") VALUES
This is VERY frustrating and I hope an answer will be found!
Guillaume
Message: 2
Date: Thu, 24 Apr 2014 21:43:43 +0200
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Subject: Re: raster2pgsql 2.1.1 on
Message-ID:
        <CABUeae-w_cXrPh_jP3oHBKKaqE9sMi+0bG1zdapOcenpXmqW4w at mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
On 24 April 2014 21:19, Guillaume Drolet <droletguillaume at gmail.com> wrote:
> I tried the same command as in my previous post on my PC at home. It's
> Windows 7 64bit as well and the cluster has the same locale
> ('French.Canadian.1252'.) and encoding (UTF8).
> The command was successful so my work colleague and I, who experiences
> the same behaviour as the one described previously on this list,
> suspect that it may be due to some problems or conflict between
> PostGIS and the hardware (we have similar systems): is this a sensible
> hypothesis?
I doubt it. I use raster2pgsql frequently on Windows, since PostGIS pre-2.0
and I have never experienced any such issues.
raster2pgsql is a standalone command line utility that generates SQL
commands and outputs them to stdout.
raster2pgsql has no run-time dependency on PostgreSQL or PostGIS.
First thing to check is: does raster2pgsql generate valid output, if
redirected to file, does the SQL commands in output file look well-formed
and complete?
If not, which SQL lines are broken?
Do the broken lines correspond to any character data in non-ASCII encodings?
For example, check if you run raster2pgsql with -F switch to add column with
the name of your raster file and the raster file name contains characters
with French accents, etc.
I'd suggest, don't use psql.exe or load any data to PostgreSQL until you
confirm raster2pgsql generates text output with complete well-formed and
valid SQL commands first.
Best regards,
Mateusz  ?oskot, http://mateusz.loskot.net
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
