[postgis-users] Accessing NWS poly data with lat/lon input
Joseph Spenner joseph85750 at yahoo.com
Fri Aug 8 08:12:49 PDT 2014
Hello, I've just got postgresql93-server installed, with postgis21-postgresql93 on a CentOS system.
I then used shp2pgsql to load in some shape files using this procedure:
http://suite.opengeo.org/docs/latest/dataadmin/pgGettingStarted/shp2pgsql.html
The shapefiles were obtained from NWS:
http://www.nws.noaa.gov/geodata/catalog/wsom/html/pubzone.htm
Everything appears to have been written to the database properly:
polydata=# select state,time_zone,zone,name,lon,lat from polys where state='CO' limit 10;
 state | time_zone | zone |               name               |      lon       |      lat
 CO    | M         | 048  | Logan County                     | -103.110114271 | 40.7246902558
 CO    | M         | 044  | Morgan County                    | -103.809823690 | 40.2627093692
 CO    | M         | 050  | Sedgwick County                  | -102.351810279 | 40.8758426210
 CO    | M         | 049  | Washington County                | -103.201287262 | 39.9710250432
 CO    | M         | 090  | Yuma County                      | -102.424258955 | 40.0029195574
 CO    | M         | 099  | Springfield Vicinity/Baca County | -102.560453567 | 37.3192132374
 CO    | M         | 097  | Las Animas Vicinity/Bent County  | -103.071690129 | 37.9551177349
 CO    | M         | 092  | Cheyenne County                  | -102.603398004 | 38.8279341557
 CO    | M         | 089  | Crowley County                   | -103.784878922 | 38.3266440954
 CO    | M         | 091  | Kit Carson County                | -102.602884309 | 39.3054124576
(10 rows)
polydata=#
My goal is to construct a query providing lat/lon such that the result returned is the single row poly containing that point.
Does anyone know how I would construct this query?
Thanks!
Regards,
Joseph Spenner
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140808/9cd92816/attachment.html>
