[postgis-users] FW: json/json.h: No such file or directory
Gery . gamejihou at hotmail.com
Sat Aug 16 13:57:46 PDT 2014
Thanks again Regina, good news, I recently successfully installed the 2.1.4dev version in my cygwin. The -lpostgres problem was solved by Marco Atzeri, here it's his message, that *.a file did the trick: https://cygwin.com/ml/cygwin/2014-08/msg00321.html.
So, you asked why, well, it's simply because I just stop rebooting my pc to a linux os, or using VM. The former was good for a while, whereas the latter was not that good at all because it was slow and my pc doesn't have much ram. I normally use several apps that only run in linux (eg. seismic unix) and are interrelated by shell scripts (eg. gmt, seismic unix, pgsql, mb, etc) as well as several that run only in windows. So, booting every time because I just needed to change somethings or manage some other things was boring. Cygwin helps me with that.
Just to summarize things, with the latest cygwin 32-bit (I installed it like 1-2 days ago) neither GEOS or GDAL actually gave error messages (some with python I think for the latter), and PostGIS installed flawlessly. All of them gave warnings, though, but they are warnings. This Cygwin latest version comes with netcdf4, json-c, libxml2, hdf5, Pgsql9.3, proj4, etc, etc, so, nicely installed. I'll ask if some other open-source software can also be added in the Science package, such as gmt, gdal, geos, su, mb, etc.
Thanks again,
Cheers,
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
> From: lr at pcorp.us
> To: postgis-users at lists.osgeo.org
> Date: Sat, 16 Aug 2014 15:05:21 -0400
> Subject: Re: [postgis-users] FW: json/json.h: No such file or directory
> Gery,
> Sorry didn't read this before I sent the other. Is there a particular
> reason you chose Cygwin to build with. For the windows packages I build
> with mingw64. Haven't used cygwin in ages.
> I can provide you with my 32-bit build chain (have a couple actually) if
> your only reason is to build for windows.
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Gery .
> Sent: Saturday, August 16, 2014 1:11 PM
> To: PostGIS Users Discussion
> Hello Regina,
> Thanks for your reply, I have these ones installed in cygwin (latest version
> 32-bit):
> Gery at gery /opt/postgis/postgis-2.1.3
> $ cygcheck -c | grep json
> json-c-debuginfo 0.11-2 OK
> libjson-c-common 0.11-2 OK
> libjson-c-devel 0.11-2 OK
> libjson-c2 0.11-2 OK
> libjson-devel 0.11-2 OK
> libjson0 0.9-1 OK
> ruby-json 1.8.0-1 OK
> Surprisingly, neither geos nor gdal has given error messages. I read some
> posts about that things were not smooth in cygwin with postgis as far as I
> remember, but here this has been the only complain. I have installed both
> libjson-c2 (version 0.11-2) and libjson0 (version 0.9-1), would that be the
> problem?
> I'll follow your suggestion and try postgis 2.1.4dev, and send a message if
> nothing improves.
> Gery
> Sent from Windows Mail
>> Date: Sat, 16 Aug 2014 12:32:37 -0400
>> directory
>> It's related to json version. Which version are you building with?
>> I suspect you are running a newer json. This should be fixed in 2.1.4
>> (2.1
>> trunk)
>> If you are building from source anyway, you might want to use our
>> 2.1.4dev or cut in the fix from
>> http://trac.osgeo.org/postgis/ticket/2723
>> Hope that helps,
>> Regina
>> http://www.postgis.us
>> http://postgis.net
>> Sent: Saturday, August 16, 2014 8:50 AM
>> Subject: [postgis-users] FW: json/json.h: No such file or directory
>> Hello,
>> I just received this after 'make' in version 2.1.3:
>> libtool: compile: gcc -g -O2 -DDLL_EXPORT -DPIC -Wall
>> -Wmissing-prototypes -I/usr/local/include -c lwin_geojson.c
>> -DDLL_EXPORT -DPIC -o .libs/lwin_geojson.o
>> lwin_geojson.c:20:23: fatal error: json/json.h: No such file or
>> directory &include <json/json.h> ^ compilation terminated.
>> Makefile:156: recipe for target 'lwin_geojson.lo' failed
>> make[1]: *** [lwin_geojson.lo] Error 1
>> make[1]: Leaving directory '/opt/postgis/postgis-2.1.3/liblwgeom'
>> GNUmakefile:14: recipe for target 'all' failed
>> make: *** [all] Error 1
>> I read that this is a problem related to Geos 3.4.2. My configuration is:
>> -------------- Compiler Info ------------- C compiler: gcc -g -O2
>> C++ compiler: g++ -g -O2
>> SQL preprocessor: /usr/bin/cpp -w -traditional-cpp -P
>> -------------- Dependencies -------------- GEOS config:
>> /usr/local/bin/geos-config GEOS version: 3.4.2 GDAL config:
>> /usr/local/bin/gdal-config GDAL version: 1.11.0 PostgreSQL config:
>> /usr/bin/pg_config PostgreSQL version: PostgreSQL 9.3.5
>> PROJ4 version: 46
>> Libxml2 config: /usr/bin/xml2-config
>> Libxml2 version: 2.9.1
>> JSON-C support: yes
>> PostGIS debug level: 0
>> Perl: /usr/bin/perl
>> --------------- Extensions --------------- PostGIS Raster: enabled
>> PostGIS
>> Topology: enabled SFCGAL support: disabled
>> -------- Documentation Generation --------
>> xsltproc: /usr/bin/xsltproc
>> xsl style sheets: /usr/share/sgml/docbook/xsl-stylesheets
>> dblatex: /usr/bin/dblatex
>> convert: /usr/bin/convert
>> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>> How can I circumvent this json/json.h problem and finish the
>> installation of postgis?
>> Gery
>> postgis-users mailing list
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
