[postgis-users] pointcloud extentions
Nicolas Ribot
nicolas.ribot at gmail.com
Wed Aug 20 03:26:42 PDT 2014
I guess you have to install Cygwin or another Linux env on Windows, then
install all necessary packages and compile PointCloud.
It will be easier, though, to install a PostGIS version on a Linux box,
then tell OpenGeoSuite to use this installation.
Nicolas
On 20 August 2014 12:17, Mohammed Kabeer <mkabeer at tamimicg.com> wrote:
> Thank you very much
> How to install in windows environment
> // Create file as pointcloud.control and copy following code in it
> # pointcloud extension
> comment = 'data type for lidar point clouds'
> default_version = '1.0'
> module_pathname = '$libdir/pointcloud'
> relocatable = true
> superuser = true
> #requires = 'postgis'
> Would you please guide me how to install in windows
> Thanks
> Kabeer
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Nicolas Ribot
> *Sent:* Wednesday, August 20, 2014 1:09 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] pointcloud extentions
> Hi,
> This extension is not part of standard postgis installation (afaik).
> You have to install it manually: https://github.com/pramsey/pointcloud
> Nicolas
> On 20 August 2014 11:37, Mohammed Kabeer <mkabeer at tamimicg.com> wrote:
> Dear Sir,
> I installed postgis with opengeosuit4. 1 (OpenGeoSuite-latest.exe) and
> created database and working fine
> I run CREATE EXTENSION postgis: // working fine
> But when I run CREATE EXTENSION pointcloud; // it gives me ERROR: could
> not open extension control file "C:/Program Files
> (x86)/Boundless/OpenGeo/bin/../pgsql/share/extension/pointcloud.control":
> No such file or directory
> SQL state: 58P01
> How to fix this problem
> Thanks
> Kabeer
> Mohammed Kabeer Ahmed | Spatial Technologies| Tamimi Consulting Group|
> Tel +966 1217 0152 | Mobile +966 545548353 | Skype: mkabeer2000
> Riyadh, Saudi Arabia
> [image: specialistCard]
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140820/0dd86206/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140820/0dd86206/attachment.jpg>
