[postgis-users] pointcloud extentions
Mohammed Kabeer
mkabeer at tamimicg.com
Wed Aug 20 03:49:48 PDT 2014
Dear Sir,
Right now I have windows environment existing
You mean I need to move to linux environment or how
Thanks
Kabeer
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Nicolas Ribot
Sent: Wednesday, August 20, 2014 1:27 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] pointcloud extentions
I guess you have to install Cygwin or another Linux env on Windows, then install all necessary packages and compile PointCloud.
It will be easier, though, to install a PostGIS version on a Linux box, then tell OpenGeoSuite to use this installation.
Nicolas
On 20 August 2014 12:17, Mohammed Kabeer <mkabeer at tamimicg.com> wrote:
Thank you very much
How to install in windows environment
// Create file as pointcloud.control and copy following code in it
# pointcloud extension
comment = 'data type for lidar point clouds'
default_version = '1.0'
module_pathname = '$libdir/pointcloud'
relocatable = true
superuser = true
#requires = 'postgis'
Would you please guide me how to install in windows
Thanks
Kabeer
Sent: Wednesday, August 20, 2014 1:09 PM
This extension is not part of standard postgis installation (afaik).
You have to install it manually: https://github.com/pramsey/pointcloud
Nicolas
On 20 August 2014 11:37, Mohammed Kabeer <mkabeer at tamimicg.com> wrote:
Dear Sir,
I installed postgis with opengeosuit4. 1 (OpenGeoSuite-latest.exe) and created database and working fine
I run CREATE EXTENSION postgis: // working fine
But when I run CREATE EXTENSION pointcloud; // it gives me ERROR: could not open extension control file "C:/Program Files (x86)/Boundless/OpenGeo/bin/../pgsql/share/extension/pointcloud.control": No such file or directory
SQL state: 58P01
How to fix this problem
Thanks
Kabeer
Mohammed Kabeer Ahmed | Spatial Technologies| Tamimi Consulting Group|
Tel +966 1217 0152 | Mobile +966 545548353 <tel:%2B966%20545548353> | Skype: mkabeer2000
Riyadh, Saudi Arabia
specialistCard
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140820/c8d2720c/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140820/c8d2720c/attachment.jpg>
