[postgis-users] Raster data questions
George Merticariu merticariug at gmail.com
Sun Dec 7 15:40:26 PST 2014
Hello Remi,
Your suggestion with point clouds worked perfectly.
Thank you!
Best regards,
George
On Wed, Dec 3, 2014 at 1:21 PM, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> I'm afraid you don't have given the most important information
> , thus not allowing to choose between a value  per row or a file per row!
> So I discuss both :
>  first hypothesys : you'll have few files at a time,
>   - number of values is not very high (few millions)
>   - you want to get parts of the data based on index (1D,2D,3D) or maybe
> value
> You will store each value of the file into a row.
> Thus  a file with a char array of size N will yield a table of N rows.
> CREATE TABLE one_value_per_row (
> gid int, --contains 1,2,..N , ordered by x,y,z
> X int,
> Y int,
> Z int,
> value smallint --or somehting like that
>  if you want your point ordered with original array index
> SELECT *
> FROM one_value_per_row
> WHERE gid BETWEEN 2 AND 45;
> More interesting, you can select 1-2-3D line/square/cube like this
> SELECT *
> WHERE X BETWEEN 2 AND 3
>   AND Y BETWEEN 56 AND 89
>   AND Z BETWEEN 21 AND 42;
> of course for this kind of querry to beb efficient, you need some index
> CREATE INDEX ON one_value_per_row (gid);--the same for all columns
> This approach __won't__ scale
> Second hypothesis : you have a great many of files (over the hundred range)
> *you will store each file in one row.*
> Now you have at least 3 options.
> * You store the data as a postgres type, the simplest is a postgres array
>     each row would contain a smallint[] (for instance)
>     This may not perform well with millions of values
>     You access your data like you would for a C char[] :  value[35%12]
>     I think it is a pretty bad idea
>  * You ask the database to store the original binary, and you have to
> create C/python function in the database  to access the data
>   (like get_values(Xmin=1,XMax=3,YMin=56,YMax=89,Zmin=21,ZMax=42))
>    this is an approach identical to the pg_pointcloud
> <https://github.com/pgpointcloud/pointcloud> project
>    For instance, your data could be stored as a 3D numpy array. slicing it
> would be then efficient and very easy (one line)
> * You don't want to redevelop, and use pg_pointcloud out of the box :
>      You consider that each value of your original array is a 3D point
>      Then each file is a point cloud stored on one row of the database.
>     you define each value of your initial array as a point X,Y,Z being the
> 3D coordinate. you store the value in an attribute, You can also store the
>      This is the easiest and most efficient out-of-the-box solution
>         (see this introduction presentation
> <http://boundlessgeo.com/wp-content/uploads/2013/10/pgpointcloud-foss4-2013.pdf>
> , and this simple to complex presentation
> <https://github.com/Remi-C/Postgres_Day_2014_10_RemiC/raw/master/presentation/A%20PostgreSQL%20Server%20for%20Point%20Cloud%20Storage%20and%20Processing.pdf>
>    you would get your data like this
>  SELECT pc_get(pt,'X'),pc_get(pt,'Y'),pc_get(pt,'Z'),pc_get(pt,'value'),
> FROM one_file_per_row,
>   PC_FilterBetween(
>        PC_FilterBetween(
>          PC_FilterBetween(point_cloud, 'X',2,3)
>        ,'Y',56,89)
>       ,'Z',21,42) as patch
>   , pc_explode(patch) AS pt
> WHERE file_name = ....
> Choosing a solution depends on a lot of factors,
> pondering performances, storage, usage, facility to create, facility ot
> maintain, etc etc.
> Cheers,
> Rémi-C
> 2014-12-02 21:07 GMT+01:00 George Merticariu <merticariug at gmail.com>:
>> Hello!
>> Thank you for your answer!
>> Please find below more information:
>> The type of data which I will insert is an 1D array of values between 0
>> and 255.
>> This array should be mapped to different dimensions:
>> 1D - grey string
>> 2D - grey image
>> 3d - grey cube
>> There will be a lot of reads from the arrays and only one write at
>> insert. The size of the array will be kept constant and will be given by
>> the file size.
>> Is there a way to import directly the 1D binary file into arrays of
>> higher dimensions or do I need to convert it first and then import it?
>> Best,
>> George
>> On Tue, Nov 25, 2014 at 5:56 PM, Rémi Cura <remi.cura at gmail.com> wrote:
>>> Hey,
>>> you don't even need postgis for this, you could store a cube per line,
>>> with a x,y,z number, indexes on it,then querry like
>>> SELECT *
>>> FROM my_cube_table
>>> WHERE x BETWEEN 100 AND 200
>>> AND y BETWEEN 23 AND 45
>>> AND z BETWEEN 45 AND 67
>>> You could alos use postgres range type.
>>> Of course you could store cube as meshes, and use pure 3D function
>>> (postgis so )
>>> etc etc
>>> It is very hard to answer you if you don't explain what you want to do
>>> with this cubes , how many you will have, ifyou read it more or write it
>>> more, what kind of data it contains, if the size of each cube may change,
>>> if you want to convert this to geo types ...
>>> Cheers,
>>> Rémi-C
>>> 2014-11-25 17:32 GMT+01:00 George Merticariu <merticariug at gmail.com>:
>>>> Hello!
>>>> I want to use PostGIS for handling 3D cubes but I couldn't figure out
>>>> how to do it from the manual.
>>>> The main tasks I want to accomplish are:
>>>> 1. Import a 1D char array file (grey cube) into a 3D cube.
>>>> 2. Retrieve sections from the cube, where a section is defined by a
>>>> domain.
>>>> Example:
>>>> Given a file of 1024*1024*1024 bytes, I want to import it into a cube
>>>> with the domain [0:1023, 0:1023, 0:1023]. Then, select the sub-domains
>>>> (examples):
>>>>    -  [100:200, 100:200, 0:100]
>>>>    -  [0:1, 0:1023, 0:1023]
>>>> Is this possible using PostiGIS? If yes, are there any detailed
>>>> tutorials which explain how to do that?
>>>> Thank you!
>>>> Best regards,
>>>> George Merticariu
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> George Merticariu
>> Jacobs University Bremen
>> B.Sc. Computer Science
>> Class of 2014
>> g.merticariu at jacobs-university.de
George Merticariu
M.Sc. Computer Science
Class of 2016
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141208/349250b7/attachment.html>
