[postgis-users] Raster data questions
Rémi Cura remi.cura at gmail.com
Mon Dec 8 01:20:44 PST 2014
You are very welcome,
it is the work of Paul Ramsey though ;-)
Cheers,
Rémi-C
2014-12-08 0:40 GMT+01:00 George Merticariu <merticariug at gmail.com>:
> Hello Remi,
> Your suggestion with point clouds worked perfectly.
> Thank you!
> Best regards,
> George
> On Wed, Dec 3, 2014 at 1:21 PM, Rémi Cura <remi.cura at gmail.com> wrote:
>> Hey,
>> I'm afraid you don't have given the most important information
>> , thus not allowing to choose between a value  per row or a file per row!
>> So I discuss both :
>>  first hypothesys : you'll have few files at a time,
>>   - number of values is not very high (few millions)
>>   - you want to get parts of the data based on index (1D,2D,3D) or maybe
>> value
>> You will store each value of the file into a row.
>> Thus  a file with a char array of size N will yield a table of N rows.
>> CREATE TABLE one_value_per_row (
>> gid int, --contains 1,2,..N , ordered by x,y,z
>> X int,
>> Y int,
>> Z int,
>> value smallint --or somehting like that
>>  if you want your point ordered with original array index
>> SELECT *
>> FROM one_value_per_row
>> WHERE gid BETWEEN 2 AND 45;
>> More interesting, you can select 1-2-3D line/square/cube like this
>> SELECT *
>> WHERE X BETWEEN 2 AND 3
>>   AND Y BETWEEN 56 AND 89
>>   AND Z BETWEEN 21 AND 42;
>> of course for this kind of querry to beb efficient, you need some index
>> CREATE INDEX ON one_value_per_row (gid);--the same for all columns
>> This approach __won't__ scale
>> Second hypothesis : you have a great many of files (over the hundred
>> range)
>> *you will store each file in one row.*
>> Now you have at least 3 options.
>> * You store the data as a postgres type, the simplest is a postgres array
>>     each row would contain a smallint[] (for instance)
>>     This may not perform well with millions of values
>>     You access your data like you would for a C char[] :  value[35%12]
>>     I think it is a pretty bad idea
>>  * You ask the database to store the original binary, and you have to
>> create C/python function in the database  to access the data
>>   (like get_values(Xmin=1,XMax=3,YMin=56,YMax=89,Zmin=21,ZMax=42))
>>    this is an approach identical to the pg_pointcloud
>> <https://github.com/pgpointcloud/pointcloud> project
>>    For instance, your data could be stored as a 3D numpy array. slicing
>> it would be then efficient and very easy (one line)
>> * You don't want to redevelop, and use pg_pointcloud out of the box :
>>      You consider that each value of your original array is a 3D point
>>      Then each file is a point cloud stored on one row of the database.
>>     you define each value of your initial array as a point X,Y,Z being
>> the 3D coordinate. you store the value in an attribute, You can also store
>> the original array index
>>      This is the easiest and most efficient out-of-the-box solution
>>         (see this introduction presentation
>> <http://boundlessgeo.com/wp-content/uploads/2013/10/pgpointcloud-foss4-2013.pdf>
>> , and this simple to complex presentation
>> <https://github.com/Remi-C/Postgres_Day_2014_10_RemiC/raw/master/presentation/A%20PostgreSQL%20Server%20for%20Point%20Cloud%20Storage%20and%20Processing.pdf>
>>    you would get your data like this
>>  SELECT pc_get(pt,'X'),pc_get(pt,'Y'),pc_get(pt,'Z'),pc_get(pt,'value'),
>> FROM one_file_per_row,
>>   PC_FilterBetween(
>>        PC_FilterBetween(
>>          PC_FilterBetween(point_cloud, 'X',2,3)
>>        ,'Y',56,89)
>>       ,'Z',21,42) as patch
>>   , pc_explode(patch) AS pt
>> WHERE file_name = ....
>> Choosing a solution depends on a lot of factors,
>> pondering performances, storage, usage, facility to create, facility ot
>> maintain, etc etc.
>> Cheers,
>> Rémi-C
>> 2014-12-02 21:07 GMT+01:00 George Merticariu <merticariug at gmail.com>:
>>> Hello!
>>> Thank you for your answer!
>>> Please find below more information:
>>> The type of data which I will insert is an 1D array of values between 0
>>> and 255.
>>> This array should be mapped to different dimensions:
>>> 1D - grey string
>>> 2D - grey image
>>> 3d - grey cube
>>> There will be a lot of reads from the arrays and only one write at
>>> insert. The size of the array will be kept constant and will be given by
>>> the file size.
>>> Is there a way to import directly the 1D binary file into arrays of
>>> higher dimensions or do I need to convert it first and then import it?
>>> Best,
>>> George
>>> On Tue, Nov 25, 2014 at 5:56 PM, Rémi Cura <remi.cura at gmail.com> wrote:
>>>> Hey,
>>>> you don't even need postgis for this, you could store a cube per line,
>>>> with a x,y,z number, indexes on it,then querry like
>>>> SELECT *
>>>> FROM my_cube_table
>>>> WHERE x BETWEEN 100 AND 200
>>>> AND y BETWEEN 23 AND 45
>>>> AND z BETWEEN 45 AND 67
>>>> You could alos use postgres range type.
>>>> Of course you could store cube as meshes, and use pure 3D function
>>>> (postgis so )
>>>> etc etc
>>>> It is very hard to answer you if you don't explain what you want to do
>>>> with this cubes , how many you will have, ifyou read it more or write it
>>>> more, what kind of data it contains, if the size of each cube may change,
>>>> if you want to convert this to geo types ...
>>>> Cheers,
>>>> Rémi-C
>>>> 2014-11-25 17:32 GMT+01:00 George Merticariu <merticariug at gmail.com>:
>>>>> Hello!
>>>>> I want to use PostGIS for handling 3D cubes but I couldn't figure out
>>>>> how to do it from the manual.
>>>>> The main tasks I want to accomplish are:
>>>>> 1. Import a 1D char array file (grey cube) into a 3D cube.
>>>>> 2. Retrieve sections from the cube, where a section is defined by a
>>>>> domain.
>>>>> Example:
>>>>> Given a file of 1024*1024*1024 bytes, I want to import it into a cube
>>>>> with the domain [0:1023, 0:1023, 0:1023]. Then, select the sub-domains
>>>>> (examples):
>>>>>    -  [100:200, 100:200, 0:100]
>>>>>    -  [0:1, 0:1023, 0:1023]
>>>>> Is this possible using PostiGIS? If yes, are there any detailed
>>>>> tutorials which explain how to do that?
>>>>> Thank you!
>>>>> Best regards,
>>>>> George Merticariu
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>> George Merticariu
>>> Jacobs University Bremen
>>> B.Sc. Computer Science
>>> Class of 2014
>>> g.merticariu at jacobs-university.de
> George Merticariu
> M.Sc. Computer Science
> Class of 2016
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141208/7ad8d922/attachment.html>
