[postgis-users] neeed help in postgis
Sandro Santilli
strk at keybit.net
Sat Dec 13 09:10:26 PST 2014
On Sat, Dec 13, 2014 at 10:50:21AM -0500, Stephen Woodbridge wrote:
> Hi Beekk,
> I can't offer help with the postgis topology, but in pgrouting we do
> this with a zlevel attribute at each node. So the water might have
> zlevel=1, the bridge would have zlevel=2 and if you had a tunnel
> going under the river it might have zlevel=0. Then when we build our
> topology for routing (NOT the same thing as postgis topology), we
> use the zlevel to separate nodes at different levels.
> I'm not sure if postgis topology has a similar mechanism.
No way to avoid a node on intersection with postgis topology
(and ISO Geometry Topology, differently from ISO Network Topology)
--strk;
