[postgis-users] neeed help in postgis
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Dec 13 07:50:21 PST 2014
Hi Beekk,
I can't offer help with the postgis topology, but in pgrouting we do
this with a zlevel attribute at each node. So the water might have
zlevel=1, the bridge would have zlevel=2 and if you had a tunnel going
under the river it might have zlevel=0. Then when we build our topology
for routing (NOT the same thing as postgis topology), we use the zlevel
to separate nodes at different levels.
I'm not sure if postgis topology has a similar mechanism.
-Steve
On 12/13/2014 9:45 AM, Beekk Meess wrote:
> hello, i m very happy to your request, thank your very much, but i
> want to use the topology but there is a lot of instructions like
> ST_AddEdgeModFace and when i add an edge for example, all topology
> relations are changing by adding an edge. i want to adding an edge
> and controlling the changint of topology. i mean i want to make more
> then one network edges or faces topology in the same topologic
> schema. in reality for example if i have a bridge above an road.
> edges representing way in the under level make a topology and edges
> connecting with the bridge making other network topology but all
> these edges in the same table. i'm sorry for my bad english again.
> -------------------------------------------- En date de : Sam
> 13.12.14, Sandro Santilli <strk at keybit.net> a écrit :
> Objet: Re: neeed help in postgis À: "Beekk Meess"
> <marabaut at yahoo.fr> Date: Samedi 13 décembre 2014, 14h27
>> but i want to use the topology but
> there is a lot of instructions like ST_AddEdgeModFace [...]
> But you're still writing to me privately, while I asked you to use
> the mailing list :)
> --strk;
> () ASCII ribbon campaign -- Keep it simple ! /\
> http://strk.keybit.net/rants/ascii_mails.txt
> _______________________________________________ postgis-users mailing
> list postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
