[postgis-users] Odd Behavior with ST_Intersects (PostGIS 2.1, Ubuntu 12.04)
Jerry Sievert
jerry at legitimatesounding.com
Sat Feb 1 10:23:47 PST 2014
After spending some time trying to track down which package/version the bug
occurs in, I found that it is actually from the upgrade of PostGIS from
2.0.4 to 2.1.1. I will see if I can spend more time to isolate it further,
but I did confirm that it is PostGIS, not one of the dependencies.
On Fri, Jan 31, 2014 at 8:33 PM, Paragon Corporation <lr at pcorp.us> wrote:
> ah found the other one:
> http://trac.osgeo.org/postgis/ticket/2556
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Paragon Corporation
> *Sent:* Friday, January 31, 2014 11:27 PM
> *To:* 'PostGIS Users Discussion'
> *Cc:* 'PostGIS Development Discussion'
> *Subject:* Re: [postgis-users] Odd Behavior with ST_Intersects (PostGIS
> 2.1,Ubuntu 12.04)
> Jerry,
> Thanks very much for the report. I had noticed what I think might be the
> same issue, but couldn't find such a short and succinct example as yours to
> reproduce.
> I have added to my original ticket:
> http://trac.osgeo.org/postgis/ticket/2422
> I think there is another ticket in our bug tracker that might be the same
> issue too but can't recall the number.
> Thanks very very much for this great example.
> Paul -- if you are watching you have work to do :)
> Thanks,
> Regina
> http://www.postgis.us
> http://postgis.net
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Jerry Sievert
> *Sent:* Friday, January 31, 2014 6:25 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] Odd Behavior with ST_Intersects (PostGIS
> 2.1,Ubuntu 12.04)
> Hello,
> I am using Ubuntu 12.04 with the official PostgreSQL apt repo (via
> https://wiki.postgresql.org/wiki/Apt). I am running into an easily
> reproducible issue, and was hoping for some help to solve this.
> When using ST_Intersects() not all rows that intersect are returned. This
> was not the case in previous versions that we have upgraded from.
> These are the steps to reproduce on a fresh install of Ubuntu 12.04 with
> all packages updated and PostGIS/PostgreSQL 9.3 installed:
> test=# CREATE TABLE test (id serial, condition_geo geography);
> CREATE TABLE
> test=# INSERT INTO test (condition_geo) VALUES
> (ST_Buffer(ST_GeogFromWKB(ST_MakePoint(20.0,30.0)),10.0));
> INSERT 0 1
> test=# SELECT id FROM test WHERE ST_Intersects("condition_geo",
> ST_Buffer(ST_GeogFromText('POINT(20.0 30.0)'), 20.0)) IS TRUE;
> id
> 1
> (1 row)
> INSERT 0 1
> id
> 1
> (1 row)
> ST_Buffer(ST_GeogFromText('POINT(20.0 30.0)'), 20.0)) IS TRUE AND id = 2;
> id
> 2
> (1 row)
> Note that the SELECT should return both rows 1 and 2 in the first SELECT.
> Any thoughts?
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140201/c907c786/attachment.html>
