[postgis-users] Odd Behavior with ST_Intersects (PostGIS 2.1, Ubuntu 12.04)
Paragon Corporation lr at pcorp.us
Sat Feb 1 18:55:59 PST 2014
Jerry,
We know it's a PostGIS bug.  The bug I think came in 2.1.0.  It was the
change in geography to use geography cache /tree as I recall.  You aren't
the first to notice (though you provided a very succinct example).  It's a
hard bug to nail where it's happening. My naive guess is that it's somewhere
around here - that's about as far into tracing I've gotten unfortunately.
http://postgis.net/docs/doxygen/2.2/d8/de3/geography__measurement__trees_8c_
a399a5e30071a3979b414ce094ff94de9.html#a399a5e30071a3979b414ce094ff94de9
(where it computes the last distance) (
<http://postgis.net/docs/doxygen/2.2/de/dc0/lwgeodetic__tree_8c_a15d46de8726
4f168426b23b4b34d75ab.html#a15d46de87264f168426b23b4b34d75ab>
circ_tree_distance_tree(tree_cache->
<http://postgis.net/docs/doxygen/2.2/d1/d12/structCircTreeGeomCache_af627139
6dbfa5645b4265f825f0e2015.html#af6271396dbfa5645b4265f825f0e2015> index,
circ_tree, s,
<http://postgis.net/docs/doxygen/2.2/d2/d54/liblwgeom__internal_8h_a946f0acf
f4fd16a65859479e9e0b9513.html#a946f0acff4fd16a65859479e9e0b9513>
FP_TOLERANCE);
and
http://postgis.net/docs/doxygen/2.2/de/dc0/lwgeodetic__tree_8c_a15d46de87264
(circ_tree_distance_tree)
As a work around if you are in a rush and until we have the  issue resolved,
you could swap out the definition of _ST_Distance with the
_ST_DistanceUncached.  It will be slower but should produce correct results.
Basically run this:
CREATE OR REPLACE FUNCTION _st_distance(geography, geography, double
precision, boolean)
  RETURNS double precision AS
'$libdir/postgis-2.2', 'geography_distance_uncached'
  LANGUAGE c IMMUTABLE STRICT
  COST 100;
See my note here:
http://trac.osgeo.org/postgis/ticket/2556
Thanks for your patience,
Regina
http://www.postgis.us
http://postgis.net
  _____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Jerry Sievert
Sent: Saturday, February 01, 2014 1:24 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Odd Behavior with ST_Intersects (PostGIS 2.1,
Ubuntu 12.04)
After spending some time trying to track down which package/version the bug
occurs in, I found that it is actually from the upgrade of PostGIS from
2.0.4 to 2.1.1.  I will see if I can spend more time to isolate it further,
but I did confirm that it is PostGIS, not one of the dependencies.
On Fri, Jan 31, 2014 at 8:33 PM, Paragon Corporation <lr at pcorp.us> wrote:
ah found the other one:
  _____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: Friday, January 31, 2014 11:27 PM
To: 'PostGIS Users Discussion'
Cc: 'PostGIS Development Discussion'
2.1,Ubuntu 12.04)
Jerry,
Thanks very much for the report.  I had noticed what I think might be the
same issue, but couldn't find such a short and succinct example as yours to
reproduce.
I have added to my original ticket:
http://trac.osgeo.org/postgis/ticket/2422
I think there is another ticket in our bug tracker that might be the same
issue too but can't recall the number.
Thanks very very much for this great example.
Paul -- if you are watching you have work to do :)
Thanks,
Regina
http://postgis.net
  _____
Sent: Friday, January 31, 2014 6:25 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Odd Behavior with ST_Intersects (PostGIS 2.1,Ubuntu
12.04)
Hello,
I am using Ubuntu 12.04 with the official PostgreSQL apt repo (via
https://wiki.postgresql.org/wiki/Apt).  I am running into an easily
reproducible issue, and was hoping for some help to solve this.
When using ST_Intersects() not all rows that intersect are returned.  This
was not the case in previous versions that we have upgraded from.
These are the steps to reproduce on a fresh install of Ubuntu 12.04 with all
packages updated and PostGIS/PostgreSQL 9.3 installed:
test=# CREATE TABLE test (id serial, condition_geo geography);
CREATE TABLE
test=# INSERT INTO test (condition_geo) VALUES
(ST_Buffer(ST_GeogFromWKB(ST_MakePoint(20.0,30.0)),10.0));
INSERT 0 1
test=# SELECT id FROM test WHERE ST_Intersects("condition_geo",
ST_Buffer(ST_GeogFromText('POINT(20.0 30.0)'), 20.0)) IS TRUE;
 id
  1
(1 row)
INSERT 0 1
 id
  1
(1 row)
ST_Buffer(ST_GeogFromText('POINT(20.0 30.0)'), 20.0)) IS TRUE AND id = 2;
 id
  2
(1 row)
Note that the SELECT should return both rows 1 and 2 in the first SELECT.
Any thoughts?
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140201/68d80e06/attachment.html>
