[postgis-users] To correct Exterior Rings
Richard LEHAUT
richard.lehaut at crpf.fr
Wed Feb 12 05:15:28 PST 2014
Hi
You're right, but these problemes are occurred after the ST_Union of few
geométies.
Thanks
Cheers,
Richard L
Le 12/02/2014 09:42, Rémi Cura a écrit :
> You can also do the same trick, but reverted.
> This time use buffer (positiv), buffer(negativ).
> This should suppress the error in exterior ring.
> I have to say this kind of filtering is not ideal to correct geometry ...
> You would probably need a more serious way of cleaning you polygon .
> Cheers,
> Rémi-C
> 2014-02-11 17:24 GMT+01:00 Nicolas Ribot <nicolas.ribot at gmail.com
> <mailto:nicolas.ribot at gmail.com>>:
> Hi,
> You should try st_buildArea, or st_polygonize, as suggested by
> Remi. It corrects these kinds of errors.
> Nicolas
> On 11 February 2014 17:21, Richard LEHAUT <richard.lehaut at crpf.fr
> <mailto:richard.lehaut at crpf.fr>> wrote:
> My problem is the exterior ring of the polygon. There are
> points inside of this ring
> http://hpics.li/2807e0d
> These points make needless segments
> http://imagik.fr/uploads/75091 (Inside black circle)
> Cheers,
> Richard L
> Le 11/02/2014 17:02, Rémi Cura a écrit :
>> What is the problem?
>> What are "internal" lines?
>> Cheers,
>> Rémi-C
>> 2014-02-11 16:59 GMT+01:00 Richard LEHAUT
>> <richard.lehaut at crpf.fr <mailto:richard.lehaut at crpf.fr>>:
>> Thanks for response
>> The fourth proposition is correct for external but not
>> internal lines : ST_Buffer (ST_Buffer (the_geom), -0.1), 0.1
>> Look http://imagik.fr/uploads/75091
>> Do you have an idea to solve this new problem?
>> Cheers,
>> Richard L
>> Le 10/02/2014 13:56, Rémi Cura a écrit :
>>>> simplify
>>>> simplify preserve topology
>>>> polygonise then filter on area,
>>>> opening operator (negativ buffer of X then positiv
>>>> buffer of X)
>>>> Cheers,
>>>> Rémi-C
>>>> 2014-02-10 13:43 GMT+01:00 Richard LEHAUT
>>>> Hi
>>>> I succeeded to correct interior rings, but I've
>>>> problem wih interior rings.
>>>> Looks this screen (black circle).
>>>> http://imagik.fr/view-rl/74788
>>>> Do you idea to resolve my problem?
>>>> Thanks
>>>> Richard L
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> <mailto:postgis-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140212/1818672a/attachment.html>
