[postgis-users] import raster
Eloi
eloi at openmailbox.org
Thu Feb 27 02:30:54 PST 2014
On 2014-02-27 11:19, Rémi Cura wrote:
> Maybe you can try to separate raster2pgsql and psql .
> First use raster2pgsqland output it to a file on you filesystem.
> Then use psql
> to execute this file.
> You could see how much time each step takes, and how much space the
> sql temp file is.
> Maybe you could use the "-Y" flag to make it faster?
Thanks for your tips Rémi, I will try that and report back.
Cheers,
Eloi
