[postgis-users] import raster
Eloi Ribeiro
eloi at openmailbox.org
Thu Feb 27 07:06:18 PST 2014
> On 2014-02-27 11:19, Rémi Cura wrote:
>> Maybe you can try to separate raster2pgsql and psql .
>> First use raster2pgsqland output it to a file on you filesystem.
>> Then use psql
>> to execute this file.
>> You could see how much time each step takes, and how much space the
>> sql temp file is.
The sql file went up to 6.6 GB.
>> Maybe you could use the "-Y" flag to make it faster?
INSERT 0 1
INSERT 0 1
INSERT 0 1
# Til here with the -Y flag was much faster, jumped from 1h 30 min to
only 13 min.
CREATE INDEX
ANALYZE
psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding SRID
constraint
CONTEXT: PL/pgSQL function "addrasterconstraints" line 53 at RETURN
scale-X constraint
scale-Y constraint
blocksize-X constraint
blocksize-Y constraint
alignment constraint
psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding number
of bands constraint
psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding pixel
type constraint
psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding nodata
value constraint
out-of-database constraint
# Til here took about 30 minutes. And from here starts the slow part.
psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Unable to get
the extent of a sample raster. Attempting memory efficient (slower)
approach
CONTEXT: PL/pgSQL function "addrasterconstraints" line 100 at
assignment
# 3h 30min have passed and still the same.
The message is clear and searching for this message I came across with
the code I think is executing [1].
There I can see that when this notice is raised it try again with
function 'st_memunion' (memory friendly but slower) after failing with
'st_collect'.
The machine where I am running this has 16 GB RAM and even so it was not
able to preform this task with 'st_collect'.
Any suggestions?
Thanks.
Cheers,
Eloi Ribeiro
[1]
https://git.osgeo.org/postgis/tags/2.0.3/raster/rt_pg/rtpostgis.sql.in.c
