[postgis-users] import raster
Bborie Park
dustymugs at gmail.com
Thu Feb 27 08:11:23 PST 2014
Do you need the maximum extent constraint? Generally, it is safe to disable
the maximum extent constraint.
-bborie
On Thu, Feb 27, 2014 at 7:06 AM, Eloi Ribeiro <eloi at openmailbox.org> wrote:
> On 2014-02-27 11:19, Rémi Cura wrote:
>>> Maybe you can try to separate raster2pgsql and psql .
>>> First use raster2pgsqland output it to a file on you filesystem.
>>> Then use psql
>>> to execute this file.
>>> You could see how much time each step takes, and how much space the
>>> sql temp file is.
> The sql file went up to 6.6 GB.
> Maybe you could use the "-Y" flag to make it faster?
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> # Til here with the -Y flag was much faster, jumped from 1h 30 min to only
> 13 min.
> CREATE INDEX
> ANALYZE
> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding SRID
> constraint
> CONTEXT: PL/pgSQL function "addrasterconstraints" line 53 at RETURN
> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding scale-X
> constraint
> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding scale-Y
> constraint
> blocksize-X constraint
> blocksize-Y constraint
> alignment constraint
> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding number
> of bands constraint
> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding pixel
> type constraint
> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Adding nodata
> value constraint
> out-of-database constraint
> # Til here took about 30 minutes. And from here starts the slow part.
> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE: Unable to get
> the extent of a sample raster. Attempting memory efficient (slower) approach
> CONTEXT: PL/pgSQL function "addrasterconstraints" line 100 at assignment
> # 3h 30min have passed and still the same.
> The message is clear and searching for this message I came across with the
> code I think is executing [1].
> There I can see that when this notice is raised it try again with function
> 'st_memunion' (memory friendly but slower) after failing with 'st_collect'.
> The machine where I am running this has 16 GB RAM and even so it was not
> able to preform this task with 'st_collect'.
> Any suggestions?
> Thanks.
> Cheers,
> Eloi Ribeiro
> [1] https://git.osgeo.org/postgis/tags/2.0.3/raster/rt_pg/
> rtpostgis.sql.in.c
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140227/61b2d0fd/attachment.html>
