[postgis-users] import raster
Eloi eloi at openmailbox.org
Thu Feb 27 08:31:27 PST 2014
Thanks bborie,
It is possible to do that in the import statement or just after the import?
Cheers,
Eloi
On February 27, 2014 5:11:23 PM CET, Bborie Park <dustymugs at gmail.com> wrote:
>Do you need the maximum extent constraint? Generally, it is safe to
>disable
>the maximum extent constraint.
>-bborie
>On Thu, Feb 27, 2014 at 7:06 AM, Eloi Ribeiro <eloi at openmailbox.org>
>wrote:
>> On 2014-02-27 11:19, Rémi Cura wrote:
>>>> Maybe you can try to separate raster2pgsql and psql .
>>>> First use raster2pgsqland output it to a file on you filesystem.
>>>> Then use psql
>>>> to execute this file.
>>>>  You could see how much time each step takes, and how much space
>the
>>>> sql temp file is.
>> The sql file went up to 6.6 GB.
>>  Maybe you could use the   "-Y" flag to make it faster?
>> INSERT 0 1
>> INSERT 0 1
>> INSERT 0 1
>> # Til here with the -Y flag was much faster, jumped from 1h 30 min to
>only
>> 13 min.
>> CREATE INDEX
>> ANALYZE
>> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE:  Adding
>SRID
>> constraint
>> CONTEXT:  PL/pgSQL function "addrasterconstraints" line 53 at RETURN
>scale-X
>> constraint
>scale-Y
>> constraint
>> blocksize-X constraint
>> blocksize-Y constraint
>> alignment constraint
>number
>> of bands constraint
>pixel
>> type constraint
>nodata
>> value constraint
>> out-of-database constraint
>> # Til here took about 30 minutes. And from here starts the slow part.
>> psql:/home/eloi/Documents/cec_l_b1i.sql:37324808: NOTICE:  Unable to
>get
>> the extent of a sample raster. Attempting memory efficient (slower)
>approach
>> CONTEXT:  PL/pgSQL function "addrasterconstraints" line 100 at
>assignment
>> # 3h 30min have passed and still the same.
>> The message is clear and searching for this message I came across
>with the
>> code I think is executing [1].
>> There I can see that when this notice is raised it try again with
>function
>> 'st_memunion' (memory friendly but slower) after failing with
>'st_collect'.
>> The machine where I am running this has 16 GB RAM and even so it was
>not
>> able to preform this task with 'st_collect'.
>> Any suggestions?
>> Thanks.
>> Cheers,
>> Eloi Ribeiro
>> [1] https://git.osgeo.org/postgis/tags/2.0.3/raster/rt_pg/
>> rtpostgis.sql.in.c
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Sent from my Android device with K-9 Mail. Please excuse my brevity.
